GM862 Guest
| GM862 can't receive any response |
Posted: Wed Apr 08, 2009 1:11 am |
i am trying to commincate with telit gm862-gps.
i have a circuit which can send sms and can make a call but i can't get any response. I tested my circuit with hyperterminal it is working correctly i can send data and receive data. and when i connect the module to hyper terminal i can send and receive data.
But can't receive any thing from module my code is simple.
while(true)
printf("ATDXXXXXXXX;");
putc(13);
response = getc();
//then i blink a led when any thing is received
when i connect it to module it calls the number but can't receive anything.
when i conncet it to hyperterminal it sends and can recieve data to.
i am using ccs 3.249 18F2620 running at 32mhz internal osc.
i am using just 3 pin connection (TX,RX,GND) and module works fine with hyperterminal with this connecion.
sory my exact code isn't here right now.
and i am using HW usart whith correct pins and i have ERRORS in #use_rs232 statement.
Any suggestions |
Posted: Wed Apr 08, 2009 4:30 am |
| post the complete code |
GM862 Guest
Posted: Wed Apr 08, 2009 4:45 am |
complete code isn't with me but i will post it 3-4 hours later.
But as i mentioned before the module and my PIC are working whit PC. |
GM862 Guest
Posted: Wed Apr 08, 2009 9:54 am |
here is my complete code
if i use my circuit with hyper terminal i get the data. when i conncet the gps module to hyperterminal i can get the data when i conncet the module to my circuit i can send data but i can't get the response.
#include <18F2620.h>
#use rs232(BAUD = 9600, XMIT = PIN_TX, RCV = PIN_RX, PARITY = N, BITS=8,ERRORS)
#use fast_io(A)
#use fast_io(B)
#fuses INTRC_IO,NOMCLR,BORV28,NOLVP,PROTECT,NOPBADEN,PUT,NOWDT
#use delay (clock = 32000000)
#include <variables.h>
setup_oscillator(OSC_32MHZ);
SETUP_ADC_PORTS(NO_ANALOGS);
port_b_pullups(TRUE);
setup_adc(ADC_OFF);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
set_tris_a(0x13);
set_tris_b(0xFF);
set_tris_c(0xC0);
delay_ms(30000);
printf("ATE0"); //echo disabled
putc(13);
printf("AT+IPR=9600");
putc(13);
while(TRUE) //sonsuz döngü içerisinde
if(BTN_1 == 0)
if(BTN_1 == 0)
if(kbhit()) gps_location[0] = getch();
printf("AT$GPSACP");
putc(13);
for(sayac = 1; sayac < 10; sayac++)
bekleme_sure = 0;
gps_location[sayac] = getch();
GM862 Guest
Posted: Wed Apr 08, 2009 10:05 am |
| and by the way i am using EZ10 board |
GM862 Guest
Posted: Wed Apr 08, 2009 11:24 am |
Problem solved.
I don't know but i received the response from interrupt it works now.
i did not understand why it was not working but for now i don't care important is it is working. |
