leejok2003
| Slow ping respond from the Ethernet board (18F4620+ENC28J60) |
Posted: Sun Mar 29, 2009 4:33 am |
HI,
Finally i have managed to build my prototyping board on PCB. I have test the board with the ping function in the command prompt. It seems that i takes longer time to respond (1s) if compare to the prototyping board i use (32ms) all ping with 32 byte...
It the problem related to the intermediate of the PIC and the ENC or the RJ45 jack's problem? |
asmallri
Joined: 12 Aug 2004 Posts: 1663 Location: Perth, Australia
| Re: Slow ping respond from the Ethernet board (18F4620+ENC28 |
Posted: Sun Mar 29, 2009 8:00 am |
| leejok2003 wrote: | ... It seems that i takes longer time to respond (1s) if compare to the prototyping board i use (32ms) all ping with 32 byte...
The problem is almost certainly software. Assuming your application is not doing anything silly then a likey culprit is a buffer management problem in the Ethernet controller (managed by the PIC). I suspect that when a packet arrives into the ENC your software is extracting from the wrong place. Then as more packets arrive (as the result of broadcast traffic) they are added to the buffer (and therefore the available packet count increases) until finally the PIC software gets to the ping packet and then responds immediately from the PICs perspective. _________________ Regards, Andrew
leejok2003
Posted: Mon Mar 30, 2009 11:23 pm |
Finally i found the problem! It's the connection problem with the crystal. The board is not receiving oscillation from the crystal, but weird, the board can respond to the request, and display the webpage with slow respond time.
By the way, it the crystal speed affects the PIC if i use use 20Mhz instead of 25Mhz which i program for it? |
