Matthew Aurand
| Output Pulse Jitter |
Posted: Thu Mar 26, 2009 6:26 pm |
Hey Guys,
I am using a 16F819 to generate some output pulses for an RC-type servo (but my output is buffered by an inverter, so my PIC pulses are active-low, usually high level). I am experiencing a jitter of one instruction cycle when using both the internal CCP module and bit-bang techniques. The CCP module I don't understand as that should output a very clean pulse, any ideas as to the source of the jitter?
I would really appreciate your input!
Here is my code-
Fuses:
#include <16F819.h>
#device adc=10
#FUSES CCPB3 //CCP pin B3
#use delay(clock=8000000)
Setup:
setup_timer_1(T1_INTERNAL|T1_DIV_BY_2); //For 1us resolution
setup_ccp1(CCP_COMPARE_SET_ON_MATCH); //Default set mode
Pulse Routine:
void output_pulse(){ //Generate output pulse (1us/step)
set_timer1(10); //Arbitrary set point to prevent accidental trigger
setup_ccp1(CCP_COMPARE_CLR_ON_MATCH); //Start CCP again for pulse gen
CCP_1 = 1;
set_timer1(1); //Reset timer
CCP_1 = out_width; //Set CCP_1 register
setup_ccp1(CCP_COMPARE_SET_ON_MATCH); //Go high again
I am quite baffled by this and am not sure what to make of it. I would love to get any insight from those of you who have heard of this problem before. (I am likely just doing something wrong)
-Matt _________________ -Matthew A. Aurand |
FvM
Posted: Fri Mar 27, 2009 12:35 am |
If I understand right, the pulsewidth in your example is affected by code execution timing, cause setup_ccp1() defines the leading edge and set_timer1(1) the trailing. Most instructions use two instruction cycles, but instruction timing isn't synchronized to timer1 prescaler. So a jitter must be expected.
Generally, there are methods for each microprocessor family to achieve a cycle accurate timing of pins, even with software generated timing. When using a hardware timer, it's essential not to reinitialize or reset the involved time base, timer1 in this case, but to keep it running continuously and manipulate only registers, that don't threaten the timebase's integrity. |
Posted: Fri Mar 27, 2009 5:41 am |
Matt,
Why aren't you using the CCP_PWM directive in setup_ccp1()? This would give you the exact PWM you want with no software intervention. |
RLScott
Posted: Fri Mar 27, 2009 6:00 am |
| FvM wrote: | | ...but instruction timing isn't synchronized to timer1 prescaler. So a jitter must be expected... |
Ah, but it is. Whenever you write to Timer 1 you automatically clear the prescaler. This synchronizes the prescaler to the instruction timing. If there are no interrupts, I see no reason why there should be any pulse-width jitter. The code is completely deterministic.
Edit: On second thought, there may be something a little strange about the way the pulse is started - with a write to Timer 1 with the exact value in CCP_1. It is not clear exactly when the "comparision" would be made in that case. It might be dependent on the previous state of the prescaler, which is in the process of being cleared by this very instruction. How about setting CCP_1 = 1 first and then doing a set_timer1(0) instead of set_timer(1)? This will allow the compare to take place in the normal way - upon a regular increment of Timer 1. With a 2:1 prescaler on Timer 1, you only need to pause for 2 instruction times for this CCP comparison to trigger before you go on with CCP_1 = out_width. _________________ Robert Scott
Real-Time Specialties
Embedded Systems Consulting
RLScott
Posted: Fri Mar 27, 2009 6:14 am |
| Anonymous wrote: | Matt,
His code shows that he is using an 8 MHz clock, so the available PWM periods are less than 2.048 msec (using the 16:1 prescaler on Timer 2). This is too short for an R/C servo signal whose on-time varies from 1 to 2 msec. Normally they repeat every 20 msec. That is why PWM cannot be used. _________________ Robert Scott
Embedded Systems Consulting |
FvM
Posted: Fri Mar 27, 2009 7:22 am |
| Quote: | | I see no reason why there should be any pulse-width jitter. The code is completely deterministic. |
Yes, I see you should be right (if TIMER1 and CCP are working as documented). Also, both edges should occur with a fixed timing related to set_timer(1). I wonder however, if it's correct to set timer(1) to a matching value immediately. It probably should be set to zero instead, to create the edge on next count.
| Code: | CCP_1 = 1;
set_timer1(0); |
If a jitter is still present, there may be a hardware issue of this PIC. I expect, that the jitter was observed in real measurement, not a simulation? |
Posted: Fri Mar 27, 2009 9:10 am |
Hey guys, I'm going to do some more quick experiments and post back - thanks for the help!
The jitter is observed in real-world, not simulation. |
Matthew Aurand
Posted: Fri Mar 27, 2009 9:37 am |
OK. The jitter is not one instruction but about 10uS peak-peak. The same jitter remains whether I do this:
output_low(OUTPUT);
delay_us(out_width);
output_high(OUTPUT);
or various OCP variations:
setup_ccp1(CCP_COMPARE_CLR_ON_MATCH); //Start CCP for falling edge
set_timer1(0);
CCP_1 = 3; //So falling edge occurs in 3us
delay_cycles(100); //Make sure it happens
CCP_1 = out_width;
set_timer1(0);
The reason I don't use PWM is that I will not be able to get terribly good servo resolution - I wanted to maximize the resolution while keeping the numbers simple (1000-2000us per output pulse). I will try PWM now and report back.
Thanks again for the help guys.
Matthew Aurand
Posted: Fri Mar 27, 2009 10:07 am |
OK - PWM is not working at all even with code that should be fine.
set_pwm1_duty(100);
setup_timer_2(T2_DIV_BY_4,127,1);
setup_ccp1(CCP_PWM);
PWM uses timer 2, so I initialize that first with an arbitrary period and post-scale of 1. (I had set it up as (T2_DIV_BY_16,255,16) to get the proper output width of 0-2.04ms and off time of 32ms) but changed it to simple parameters to see what I was doing wrong.
I suspect that the internal clock is not stable enough - but I have written PBP code with the same part that exhibited no jitter with simple bit-banging.
