Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
...Line-by-line software access to I2C
PICman
PostPosted: Wed Mar 25, 2009 5:02 am     Reply with quote
This code is a "do-nothing" code that shows how I2C works. It continuously writes data into a 24LC256 I2C serial EEPROM and then checks it's contents for data integrity. Comments are sent on RB2 in 9600,n,8,1 (TTL)
The data is generated by a LFSR PRBG so it is random looking.
It's main goal is to show the user how I2C works and to implement I2C in microcontrollers that do not have I2C implemented.
//    My first experiences with I2C: EEPPROMS.
//    I didn't want with the tiny 24LC00 and many
//    electronics stores hold the 24LC256. So i
//    chose it. The 24LC256 holds 262144 bits of
//    data organized in a 32kB fashion (32768 * 8)
//    This firmware includes random R/W procedures
//    for the 24LC256 I2C serial EEPROM.
//    This firmware is aimed at PIC's that do
//    not include the integrated I2C protocol. It's
//    goal is also to explain you how I2C works.
//              _________  _________
//           __|         \/         |__
//   Ground |__|A0               Vdd|__| +5V
//           __|                 __ |__
//   Ground |__|A1    EEPROM     WE |__| Ground to write, +5V to protect.
//           __|     24LC256        |__
//   Ground |__|A2               SCL|__|Serial CLock
//           __|                    |__
//   Ground |__|Vss              SDA|__|Serial DAta
//             |____________________|
// I2C lines:
// What is interesting with I2C (developed by
// Philips), is that only two lines are required to access
// I2C devices. Those two lines are: SDA (Serial DAta) et SCL
// (Serial CLock).
// Another important feature of I2C is that ALL I2C devices
// can ONLY pull the lines LOW (to ground). Never, an I2C
// device may pull HIGH a line. Pulling-up the SDA and SCL
// lines is done by two pull-up RESISTORS (one per line).
// The suggested value for pullup resistors is 4700-20k ohms.
//    Waveforms:
// In the I2C protocol, normal address/read/write on the SDA
// line is done ONLY when the SCL line is LOW.
// The ONLY times when SDA is transited while SCL is high is
// on the (S)tart and sto(P) commands.
//       ____S(tart)    //       (sto)P___    //
//    SDA    \_______   // ___________/   SDA //
//       _________      //       _________    //
//    SCL         \__   // _____/         SCL //
//         ___     ___     ___     ___     ___     ___     ___     ___    ___
//  SCL  _/ 1 \___/ 0 \___/ 1 \___/ 0 \___/ A2\___/ A1\___/ A0\___/r/w\__/ack\
//       _______         _______
//  Mas_/       \_______/       \_______________________________________
//  Sla        \_____/
// For EEPROMS, 4 first bits MUST BE set at 1010.
// Every other value will be adressed to another
// component and will be ignored by EEPROMS.
// Bits A2, A1 and A0 on the stream must correlate with the hardwired
// logic states of corresponding pins (reapectively, pins 3, 2 and 1)
// of the I.C.
// Every other combination will be ignored by the EEPROM. This
// feature allows the user to use several (up to eight) 24LC256's
// on the same I2C pair by using different hardwired combinations on
// pins A2-0.
// For now, all A0-2 pins are tied to ground (Vss).sont à ground avec Vss.
//               PIC16F648A
// RB1 = RXD
// RB2 = TXD
//           __|         \/         |__
//          |__|Ra2              Ra1|__|SDA
//           __|                    |__
//          |__|Ra3              Ra0|__|SCL
//           __|                    |__
//          |__|Ra4            clkin|__|
//           __|____                |__
//       +5V|__|MCLR/Vpp      clkout|__|
//           __|                    |__
//        0V|__|Vss              Vdd|__| +5V
//           __|                    |__
//          |__|Rb0/int  Rb7/ICSPDAT|__|
//           __|                    |__
//          |__|Rb1          Rb6/PGC|__|
//           __|                    |__
// 9600baud |__|Rb2              Rb5|__|
//           __|                    |__
//          |__|Rb3              Rb4|__|
#include <16F648A.h>
//#FUSES XT,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR,NOLVP,NOCPD
//#use fast_io(b)  // We DO want to work around with TRIS (I2C port)
#use rs232(baud=9600,parity=N,xmit=pin_b2,rcv=pin_b1,bits=8)
#FUSES intrc,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR,NOLVP,NOCPD
   //no master clear a5 (reset) ;cpd barrer eedata;nolvp lo-volt prog
void rad(void);           //
void init_pic(void);      //
int8 i2c_read(void);      //
void i2c_write(int8);     //
void S(void);             //
void P(void);             // P R O T O T Y P E S
void envoi_donnees(int1); //
void envoi_octet(int8);   //
int1 lire_donnees(void);  //
void aff_err(int8);       //
int8 adresse_haute;       //
int8 adresse_basse;       //
int8 donnee;              //
int8 hasard;              //
int8 x0,x1,x2,x3,x4,x5;   //
int8 x6,x7,y;             //
//#ZERO_RAM
//#int_RTCC
void main()                                                             /////
   int8 donnee,compteur,compteur2;                                      /////
   int1 valide;                                                         /////
   int16 nbre_erreurs,nbre_prog,octets_ecrits;                          /////
   init_pic();                                                          /////
   adresse_haute=0x00; // Adresse dans un 24LC256: 0x0000-0x07FF        /////
   adresse_basse=0x00; // Adresse basse = 0-255 haute=0-127             /////
   x0=174;  // Initialisation                                           /////
   x1=152;  // RAD                                                      /////
   x2=67;   //                                                          /////
   x3=223;  // Here, i initialise an LFSR (Linear Feedback Shift        /////
   x4=98;   // Register) to be able to always generate the same         /////
   x5=42;   // pseudo-random stream. This way, i will be able, later,   /////
   x6=135;  // to re-initialise the LFSR the same way to start the      /////
   x7=201;  // verify routine with the same data.                       /////
   for(compteur=0;compteur<3;compteur++)                                /////
      printf("\n\r----------Writing I2C EEPROM-------------------");    /////
   printf("\n\r");                                                      /////
   compteur2=0;                                                         /////
   nbre_prog=0;                                                         /////
   octets_ecrits=0;                                                     /////
   valide=1;                                                            /////
   while(valide)                                                        /////
      rad();                                                            /////
      donnee=i2c_read();                    // Pre-read. If the correct /////
      if(donnee==hasard)                    // data is already present  /////
         compteur2++;                       // in the EEPROM, i don't   /////
      else                                  // touch it. This procedure /////
      {                                     // has two advantages:      /////
         printf("\n\rAdr: %2X%2X: ",        //                          /////
            adresse_haute,adresse_basse);   //                          /////
         printf(" ecrit: %2X",hasard);      //                          /////
         i2c_write(hasard);                 // 1) Much faster           /////
         donnee=i2c_read();                 // 2) No useless            /////
         printf(" Lu: %2X",donnee);         //    writes on             /////
         if(donnee==hasard)                 //    write-limited EEPROM  /////
            octets_ecrits++;                //    cells.                /////
      if(donnee==hasard)                    //                          /////
         nbre_prog++;                       //                          /////
      else                                  //                          /////
         aff_err(13);                       //                          /////
         if(adresse_basse==255)           //                            /////
            if(adresse_haute==127)        // Address counter            /////
               valide=0;                  // Generates valid addresses  /////
         }                                // between 0x0000 and 0x7FFF  /////
         adresse_basse++;                 // (24LC256)                  /////
         if(adresse_basse==0)             //                            /////
            adresse_haute++;              //                            /////
      if(compteur2==0)                    // At each 256 correct        /////
         printf(".");                     // verifications              /////
   printf("\n\r%lu=bytes written during this session",octets_ecrits);   /////
   printf("\n\r%lu=Total of good bytes:",nbre_prog);                    /////
   while(1)                                                             /////
      printf("\n\r--------Verification of I2C EEPROM-------------");    /////
      nbre_erreurs=0;                                                   /////
      adresse_haute=0x00;                                               /////
      adresse_basse=0x00;                                               /////
////////////// LFSR Initialisation                                      /////
   x0=174;  //                                                          /////
   x1=152;  // Here, i initialise the LFSR the same way as i did on     /////
   x2=67;   // beginning. This way, the LFSR will generate the EXACT    /////
   x3=223;  // same pseudorandom stream for verification as it did on   /////
   x4=98;   // writing. This way, i can fill the EEPROM with random     /////
   x5=42;   // looking data then, i can test it's data integrity.       /////
   x6=135;  //                                                          /////
   x7=201;  //                                                          /////
      valide=1;                            // Verification of EEPROM's  /////
      while(valide)                        // data contents.            /////
         rad();                            //                           /////
         donnee=i2c_read();                //                           /////
         if(donnee!=hasard)                //                           /////
            printf(" %X%X",adresse_haute,  //                           /////
            nbre_erreurs++;                //                           /////
            printf("+");                   //                         /////
               valide=0;                   //                       /////
         adresse_basse++;                  //                     /////
      printf("\n\rTotal: %lu error(s)",    //                /////
              nbre_erreurs);               //               /////
void init_pic(void)                                      //
   output_a(0); // IT IS IMPORTANT to set both bits 0    //
                // and 1 to LOW and MAINTAIN them LOW    //
                // throughout the whole program !        //
                // REMEMBER ! an I2C device CAN NOT      //
                // pull high an I2C line , master or     //
                // slave !                               //
   output_b(0);                                          //
   set_tris_a(0b11111111);  // gauche=bit7, droite=bit0  //
   set_tris_b(0b11111011);  // gauche=bit7, droite=bit0  //
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);            //
   setup_timer_1(T1_DISABLED);                           // PIC
   setup_timer_2(T2_DISABLED,0,1);                       // initialisation
   setup_comparator(NC_NC_NC_NC);  //not connected       // Routine.
   setup_vref(FALSE);              // not used           //
   disable_interrupts(INT_RTCC);                         //
   disable_interrupts(GLOBAL);                           //
//   setup_oscillator(False);                            //
   port_b_pullups(true);                                 //
int8 i2c_read()
   int1 ack,ein;                                                   //
   int8 rot;                                                       //
   int8 compteur;                                                  //
   S();  // Start                                                  //
        // I2C serial
////////////////////////                                           // EEPROM
   envoi_octet(0xA0); // ADRESSAGE/ÉCRITURE                        // reading
   envoi_octet(adresse_haute);  // Send                            //
////////////////////////////////// correct                         //
   envoi_octet(adresse_basse);  // address to                      //
////////////////////////////////// EEPROM.                         //
/////////// Pour la lecture du EEPROM. on doit                     //
   S();  // exécuter un second "Start" après                       //
/////////// l'adressage...                                         //
//////////////////////// ...et on envoie                           //
   envoi_octet(0xA1); // une commande de                           // I2C serial
//////////////////////// lecture                                   // EEPROM
        // reading
   donnee=0;                    // I2C EEPROM reading routine by   //
                                // itself.                         //
   compteur=7;                  //                                 //
   while(!bit_test(compteur,7)) // For tha, the "rot" variable is  //
   {                            // used. "rot"'s bit 0 is loaded   //
#asm                            // with the read bit on the I2C's  //
      rlf rot,f                 // SDA line.                       //
#endasm                         //                                 //
      ein=lire_donnees();       // Bertween each bit loading, the  //
                                // "rot" variable is rotated left. //
      bit_clear(rot,0);         //                                 //
      if(ein)                   // After eight, the "rot" variable //
         bit_set(rot,0);        // is loaded with the full         //
      compteur--;               // EEPROM's byte, the MSB loaded   //
   }                            // first.                          //
////////////////////////// Final ACK                               //
   ack=lire_donnees();  //                                         //
   if(ack==0)           // Here, at the end of byte read, the     //
      aff_err(11);      // slave EEPROM MUST NOT send an ACK.    //
   P();  // stoP                                             //
   return(rot);                                           //
void i2c_write(int8 octet)
   int1 ack,valide;                            //
   int8 limite_ecriture;                       //
   S();  // Start                              //
   envoi_octet(0xA0); // ADRESSING/WRITING     //
///////////////////////// Send byte to be      //
   envoi_octet(octet); // written into the     //
/////////// At this stoP, EEPROM writes        //
   P();  // the byte in it's internal memory   //
/////////// cells.                             // Écriture du
                                               // EEPRM I2C
   limite_ecriture=0;     //                   //
   valide=0;              // Here, we send a   //
   while(valide==0)       // check byte to the //
   {                      // EEPROM. It will   //
   ///////////            // reply with an ACK //
      S();  // Start      // only when the     //
   ///////////            // writing procedure //
      envoi_donnees(1);   // is completed.     //
      envoi_donnees(0);   //                   //
      envoi_donnees(1);   //                   //
      if(ack==0)          ///////        //
         valide=1;             //       //
      if(limite_ecriture>253)  //      //
         aff_err(12);     ///////    //
         valide=1;        //        //
      P();  // stoP       //     //
      limite_ecriture++;  //   //
void S(void)                                           //
   int1 valide;                                        //
   int8 essais;                                        //
   set_tris_a(0b11111111); // Eneryone up !            //
                           // Throughout this          //
                           // program, TRIS is used    //
                           // to either pull down a    //
                           // line or RELEASE it to    //
                           // high (via the pullup     //
                           // resistors).              //
                           // Bits 0 (SCL) and 1 (SDA) //
                           // are either RESET LOW to  //
                           // pull down or SET HIGH to //
                           // release the              //
                           // corresponding line.      //
   delay_us(4);                                        //
//////////////////////////////////////////// We check  //
   if(!input_state(40)||!input_state(41)) // that BOTH //
      aff_err(7);                         // SDA and   //
//////////////////////////////////////////// SCL=High  //
   essais=0;                        //                 //
   valide=0;                        //                 //
   while(valide==0)                 //                 //
   {                                // SDA is pulled   // Start
      set_tris_a(0b11111101);       // down.           // routine.
      delay_us(4);                  //                 //
      if(!input_state(41))          //                 //
         valide=1;                  // SDA is tested   //
      else                          // to be sure it's //
      {                             // LO.             //
         aff_err(0);                //                 //
         essais++;                  //                 //
         if(essais>7)               //                 //
            valide=1;               //                 //
   essais=0;                        //                 //
   valide=0;                        //                 //
   while(valide==0)                 //                 // Start
   {                                // Then, SCL is    // routine.
      set_tris_a(0b11111100);       // pulled down.    //
      delay_us(4);                  //                 //
      if(!input_state(40))          // And we check    //
         valide=1;                  // that SCL is     //
      else                          // LOW.            //
         aff_err(1);                //                 //
         essais++;                  //                 //
         if(essais>7)               //                 //
            valide=1;               //                 //
   delay_us(4);                     //                 //
void P(void)                                      //
   int1 valide=0;                                 //
   int8 essais;                                   //
///////////////////////////// Before releasing    //
   set_tris_a(0b11111100); // SCL, we must get    //
   delay_us(4);            // sure that SDA is    //
///////////////////////////// LOW.                //
   essais=0;                  //                  //
   valide=0;                  //                  //
   {                          // We release SCL   //
      set_tris_a(0b11111101); // high...          // stoP
      delay_us(4);            //                  // routine
      if(input_state(40))     // SCL is verified  //
         valide=1;            // for it's         //
      else                    // "highness" !     //
         aff_err(1);          //                  //
         essais++;            //                  //
         if(essais>7)         //                  //
            valide=1;         //                  //
   delay_us(4);                                   //
   essais=0;                  //                  //
   valide=0;                  // THEN, SDA is     //
   while(valide==0)           // released high.   //
      set_tris_a(0b11111111); //                 // stoP
      if(input_state(41))     // SDA is       //
         valide=1;            // tested      //
      else                    // high.      //
         aff_err(10);         //          //
         essais++;            //         //
         if(essais>7)         //        //
            valide=1;         //       //
void envoi_octet(int8 rot)                               //
{                               // The "to-be-sent" byte // PIC-to-I2C EEPROM
   int1 ein,ack;                // is transferred to the // byte sending routine.
   int8 compteur;               // "rot" variable.       //
   compteur=7;                  //                       //
   while(!bit_test(compteur,7)) // From "rot", we send   //
   {                            // the MSB (bit 7) bit   //
      ein=0;                    // to I2C.               //
      if(rot&0x80)              //                       //
         ein=1;                 // Then, "rot" is        //
      envoi_donnees(ein);       // rotated left to pass  //
#asm                            // to the next bit.      //
      rlf rot,f                 //                       //
      bcf rot,0                 // This way, all eight   //
#endasm                         // bits are sent to I2C, //
      compteur--;               // one at a time,        //
   }                            // starting with         //
////////////////////////////////// the heaviest one.     //
///////////////////////// At the end of each byte, the   //
   ack=lire_donnees(); // PIC master waits for an        //
   if(ack==1)          // ACKnowledge from the slave     //
      aff_err(6);      // EEPROM. To send it's ACK, the  //
///////////////////////// slave PULLS DOWN SDA. The      //
// master releases it's SDA line and checks that the SDA //
// line is HELD DOWN by the slave.                       //
void envoi_donnees(int1 donnee)                               //
   int1 valide=0;                                             //
   int8 essais;                                               //
   essais=0;                  //                              //
   {                          // SCL is pulled down           //
      set_tris_a(0b11111110); // while SDA is left free to go //
      delay_us(4);            // high.                        //
///////////////////////////// Master checks that SDA goes HI. // Bit sending
      if(!input_state(41)) // If SDA id held LOW, then the    // procedure
         aff_err(11);      // slave EEPROM has sent an        // on I2C port.
                           // unattended ACK.                 //
      if(donnee==1)               // SDA is either held LOW   //
         set_tris_a(0b11111110);  // or released HIGH.        //
      else                        // obeying to the data bit. //
         set_tris_a(0b11111100);  //                          //
      delay_us(4);                //                          //
      if(donnee)              //                              //
         if(input_state(41))  // Verification. Has the SDA    //
            valide=1;         // line followed the DATA bit ? //
         else                 //                              //
            aff_err(2);       //                              //
            essais++;         //                              //
            if(essais>7)      //                              //
               valide=1;      //                              // Bit sending
         }                    //                              // procedure
      }                       //                              // on I2C port.
      else                    //                              //
            valide=1;         //                              //
         else                 //                              //
            aff_err(3);       //                              //
            essais++;         //                              //
            if(essais>7)      //                              //
               valide=1;      //                              //
   essais=0;                      //                          //
   valide=0;                      //                          //
      if(donnee)                  //                          //
         set_tris_a(0b11111111);  //                          // Bit sending
      else                        // SCL is released HIGH...  // procedure
         set_tris_a(0b11111101);  //                          // on I2C port.
      delay_us(4);                //                          //
      if(input_state(40))         // Is SCL HIGH ?            //
         valide=1;                //                          //
      else                        //                          //
         aff_err(4);              //                          //
         essais++;                //                          //
         if(essais>7)             //                          //
            valide=1;             //                          //
   essais=0;                     //                           //
   valide=0;                     //                           //
      if(donnee)                 // ...and SCL is pulled      //
         set_tris_a(0b11111110); // down.                     // Bit sending
      else                       //                           // procedure
         set_tris_a(0b11111100); //                           // on I2C port.
      delay_us(4);               //                           //
      if(!input_state(40))       // ...and checked LOW.       //
         valide=1;               //                          //
      else                       //                         //
         aff_err(3);            //                        //
         essais++;             //                        //
         if(essais>7)         //                        //
            valide=1;        //                        //
   delay_us(4);                                   //
int1 lire_donnees(void)                                   //
   int1 lecture;                                          //
   int1 valide=0;                                         //
   int8 essais;                                           //
   /*=-=*//*=-=*//*=-=*//*=-=*//*=-=*/                    // Bit reading
////////////////////////////////                          // procedure
      set_tris_a(0b11111110); // SDA is left high...      // on I2C port.
      delay_us(4);            //                          //
   essais=0;                  //                          //
   valide=0;                  //                          //
   {                          // ...and SCL is left HIGH. //
      set_tris_a(0b11111111); //                          // Réception
                              //                          // d'un
      delay_us(4);            // delay                    // bit sur
                              //                          // le port
      if(input_state(40))     // We check that SCL is     // I2C
         valide=1;            // high.                    //
      else                    //                          //
         aff_err(5);          //                          //
         essais++;            //                          //
         if(essais>7)         //                          //
            valide=1;         //                          //
   lecture=0;          //                                 //
   if(input_state(41)) // SDA line is read...             //
      lecture=1;       //                                 //
                       // ...and saved on "lecture"       //
   delay_us(4);        // boolean.                        //
   essais=0;                  //                          //
   valide=0;                  //                         //
   while(valide==0)           // ...and SCL is pulled   //
   {                          // DOWN.                 //
      set_tris_a(0b11111110); //                      //
      delay_us(4);            //                    //
      if(!input_state(40))    // and checked LOW. //
         valide=1;            //                 //
      else                    //                //
         aff_err(5);          //              //
         essais++;            //             //
         if(essais>7)         //            //
            valide=1;         //           //
   delay_us(4);                        //
   return(lecture);                   //
void aff_err(int8 erreur)                                                    //
   if(erreur!=13)                                                            //
      printf("\n\rError # %u: ",erreur);                                     //
   if(erreur==0)                                                             //
      printf("SDA not down in (S)tart");                                     //
   if(erreur==1)                                                             //
      printf("SCL not down in (S)tart or not UP is sto(P)");                 //
   if(erreur==2)                                                             //
      printf("SDA not following DATA HIGH in sending to EEPROM");            //
   if(erreur==3)                                                             //
      printf("SDA not following DATA  LOW in sending to EEPROM");            //
   if(erreur==4)                                                             //
      printf("SCL not rising high when data sent to EEPROM");                //
   if(erreur==5)                                                             //
      printf("SCL not following on data reading/ACK of EEPROM");             //
   if(erreur==6)                                                            //
      printf("NAK!");                                                      //
   if(erreur==7)                                                          //
      printf("SCL and SDA lines not HI before (S)tart");                 //
   if(erreur==8)                                                        //
      printf("SCL line not HI after sto(P)");                          //
   if(erreur==9)                                                      //
      printf("SDA line not HI after sto(P)");                        //
   if(erreur==10)                                                   //
      printf("SDA not going HI during sto(P)");                    //
   if(erreur==11)                                                 // Error messages
      printf("Unattended ACK !!");                               //
   if(erreur==12)                                               //
      printf("Writing time limit exceeded");                   //
   if(erreur==13)                                             //
      printf(" Data not written (WP ?)");                    //
   delay_ms(100);                                           //
void rad(void)                    //
   int8 c2;                       //
#asm                              //
   movlw 8  // Eight times to     //
   movwf c2 // obtain a byte      //
boucle2:                          //
                                  // LFSR used
   bsf   y,0  // ODD              // to generate
                                  // pseudo-random
   btfsc x0,5 // Multi-input XOR  // data.
   incf  y    // gate. (INCF acts //
   btfsc x1,6 // as a XOR on "y"  //
   incf  y    // bit 0)           //
   btfsc x2,4 //                  //
   incf  y    //                  //
   btfsc x3,7 //                  //
   incf  y    //                  //
   btfsc x4,2 //                  //
   incf  y    //                  //
   btfsc x5,3 //                  //
   incf  y    //                  //
   btfsc x6,4 //                  //
   incf  y    //                  //
   btfsc x7,7 //                  //
   incf  y    //                  //
   rlf   x0,f  // LEFT rotate     // LFSR
   rlf   x1,f  //                 //
   rlf   x2,f  //                 //
   rlf   x3,f  //                 //
   rlf   x4,f  //                 //
   rlf   x5,f  //                 //
   rlf   x6,f  //                 //
   rlf   x7,f  //                 //
   bsf   x0,0  // Access to       //
   btfss y,0   // bit 0 of LFSR   //
   bcf   x0,0  // after bit       //
               // rotate          //
   decfsz c2,f                    //
   goto boucle2                   //
   movf  x0,w                     //
   movwf hasard                   //
#endasm                           //
   return;                        //
