pyu
Posted: Mon Mar 16, 2009 9:27 am |
Why didn't you use DS18B20 ? It has almost the same price. |
Alioshag
Posted: Mon Mar 16, 2009 11:20 am |
I got it as a free sample. |
Borke
Posted: Tue Mar 31, 2009 7:44 am |
I'm having problems with output_high(), output_low(), output_bit(), output_float(), shift_right().... and delay functions. Compiler is not recognizing this functions. I get "undefined symbols" error. I use PIC12f629 and I 've included its .h file. Compiler is HI-TECH STD and I use MPLAB. Where can I find their definitions, or how can I cope with that? Can somebody help me? |
bolke
Posted: Fri Apr 17, 2009 3:29 am |
The examples used here are for the ccs compiler, not MPLAB.
You should search for equivelant function in MPLAB. |
ishmael
problem |
Posted: Tue Jun 09, 2009 1:45 am |
Hello. I have a problem that drives me insane. I am sure it is in simulation or fuses. Both temperature nibbles are always 255, so the result returned from read() is always -0.5. Has anyone else met this problem ?
I attached the pull-up, I use a pic16f648A, and the pin is B5 (or B4, I tried both, no result).
Please help.  |
Shamber
Alarm Search |
Posted: Thu Jun 18, 2009 7:26 am |
Hello.
Does anybody help me with alarm search procedure? |
jruibarroso
strange behavior on temperatures below zero |
Posted: Tue Jun 23, 2009 3:13 pm |
When temperatures are above zero (>0º) display shows correct values but when is below 0º (<0º) strange values appears (~65535). Can anyone tell me how can I correct this ?
temperature = ds1820_read();
printf(lcd_putc,"TEMP: %3.1f ", temperature);
Posted: Sun Jun 28, 2009 3:42 pm |
What code did you use ? There are several versions of the driver in
this thread:
1. Han Solo
2. scanan
3. xokolatecake (2nd post)
What sensor did you use ?
A. ds18B20
B. ds18B20-PAR
C. ds18S20
I used the first one, ds18B20, and the original Han Solo code.
I configured the code for the ds18B20, as shown in his post:
Code: | //result = (float) temp3 / 2.0; // (Commented out) for DS18S20
result = (float) temp3 / 16.0; //Calculation for DS18B20 |
I got 24.0 degrees C at room temperature. If I use "Chill Spray" to
freeze the ds18B20, then it displays -10.1 degrees C. It's working.
This was tested with compiler vs. 4.093 and a 16F877A running at 20 MHz.
I put the ds18B20 on pin C2. I edited the 1wire.c code to use pin C2
instead of pin A0. That's because on the PicDem2-Plus board, pin A0
is connected to external circuits, but pin C2 is free for use. |
xuxa
display only shows -0.5 C |
Posted: Tue Jul 07, 2009 8:00 pm |
I am having the same problem of ''ishmael'' and I use CCS in Mplab, I've tried the 16f628a and the 16f877a, both only shows -0.5 C on display...
I'm from Brazil, my english is not perfect, thanks for any help |
ishmael
Posted: Tue Jul 07, 2009 11:54 pm |
xuxa, I solved the problem. I'm sorry I haven't posted a follow-up, it's just that the project is my bachelor's degree, and the exam is tomorrow, so I am a bit stressed. As far as I can remember, the -0.5 problem in the proteus simulation got solved when I loaded the proper configuration word onto the pic (from the end of the ccs exported lst file). If necessary, delete and add the pic and/or ds18s20, or even start a new project (maybe there are some bugs regarding applying the changes to those settings). Also pay attention to the oscillator setting, so that the pic speed you used in the C code, will match the speed set up in proteus.
And if your problem is not in simulation, remember to attach the pull-up resistor to the 1-wire bus. Upon checking my original post, I discovered I changed the port to, it's RA6 used as I/O , - pic uses internal oscillator. try using my fuse list : NOWDT, INTRC_IO, MCLR, PUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD
config word : 0x3F70
Hope it will work for you too. |
xuxa
-0.5 C problem |
Posted: Wed Jul 08, 2009 3:03 pm |
In the project with 16f877A, I solved the problem using the same oscillator setting as I 've been using in my CCS code (20Mhz). Than the LCD only displayed multiples of 8, like: -16 C, -8 C, 0 C, 8 C, 16 C .....So I went to the ds1820.c code and changed the configuration to ds18B20, in a escale of 0.1 , (just by changing the comment of two lines):
//result = (float) temp3 / 2.0; //Calculation for DS18S20 with 0.5 deg C resolution
result = (float) temp3 / 16.0; //Calculation for DS18B20 with 0.1 deg C resolution
So....it worked fine in simulation!
To the 16f628A project, it worked too, but the configuration of the fuses and the clock are :
Code: | #use delay(clock=4000000)
#fuses NOWDT, HS, PUT, NOPROTECT, BROWNOUT, MCLR, NOLVP, NOCPD
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP,NOMCLR |
Thanks very much!
I will try it on Protoboard next month, bye |
milkman41
Posted: Fri Mar 05, 2010 3:01 pm |
Hi all,
I'm using the original code posted by Han Solo on the first page, and I can't get a temperature other than 85 C, which I think I read was the startup temperature. I'm using a PIC16F876A with a DS18B20. The code I'm using is pretty much exactly the one Han Solo posted; all I've changed is the one wire pin, and then made some minor changes to the main code, but nothing to any of the actual one wire functions. Any help would be greatly, greatly appreciated.
thanks. |
deperkin
ds18s20 |
Posted: Mon Sep 20, 2010 1:56 pm |
I am trying to connect a ds18s20. (I am using a 4.7k pullup).
I am using the original hans solo code, with the only difference that the clock is set to 500 kHz. And I am trying to use pin D2 on an 18F4550.
I also am constantly reading a -0.5 C temperature.
Any ideas? Due to other things on the circuit I need to stick with this clock speed.
I am using compiler 4.093 as well.
I am NOT using Proteus.
If I use the updated code from http://www.ccsinfo.com/forum/viewtopic.php?t=42648&highlight=ds1820
then I constantly get 4095.0 C
I have also tried various input pins.
Thanks all! |
atai21
Posted: Tue May 10, 2011 1:49 am |
I'm sorry but I don't understand what this line means:
setup_adc_ports(no_ANALOGS);
Does it mean I can't put analog in my code? If I want to measure voltage from solar cell, I need to connect it with pin A3. Can someone help me? |
tejca
Posted: Mon Oct 03, 2011 2:34 pm |
atai21 wrote: | I'm sorry but I don't understand what this line means:
it means analog-digital converter on specific ports are disabled and yes that part of code means you can not put analog on pins which have that converter. _________________ --
Not Found (aka 404)
You're looking for something that does not, has not, will not, might not or
must not exist ...
... but you're always welcome to search for it. |
