What mean of prevent re-entrancy ?
sorasit46
PostPosted: Sat Mar 14, 2009 11:50 am     Reply with quote
Hi!
>>> Warning 216 "guard.c" Line 520(0,1): Interrupts disabled during call to prevent re-entrancy: (@FLT)
>>> Warning 216 "guard.c" Line 520(0,1): Interrupts disabled during call to prevent re-entrancy: (@delay_ms1)
>>> Warning 216 "guard.c" Line 520(0,1): Interrupts disabled during call to prevent re-entrancy: (@DIV1616)
>>> Warning 216 "guard.c" Line 520(0,1): Interrupts disabled during call to prevent re-entrancy: (ReadCh)
1. I'm not understand this warning. Who can explain?
2. This warning is serious or not matter?
2. How to correct this warning?
Regards
dyeatman
PostPosted: Sat Mar 14, 2009 12:05 pm     Reply with quote
This has been asked many, many times on this board (including just a
few days ago).
Use the search option. Search on "Interrupts disabled during call " and
select all search terms. You will find lots of info on what you are asking.
PostPosted: Sat Mar 14, 2009 12:10 pm     Reply with quote
Piclist has an article on it:
http://www.piclist.com/techref/microchip/sstack.htm
RLScott
Re: What mean of prevent re-entrancy ?
PostPosted: Sat Mar 14, 2009 7:39 pm     Reply with quote
This warning is not serious if the call in "guard.c" Line 520 is one for which you don't mind having interrupts disabled. If the call cited is a function that is very short and will return quickly, then it may be OK to just accept the warning and let the interrupts be disabled for the duration of the call. On the other hand, if you need to ensure low latency for your interrupts and cannot tolerate interrupts being disabled for the duration of that call, then you need to do something about it. The "something" can be found by searching the resources already cited in other posts in this thread.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
sorasit46
PostPosted: Sun Mar 15, 2009 5:19 am     Reply with quote
RLScott wrote:
This warning is not serious if the call in "guard.c" Line 520 is one for which you don't mind having interrupts disabled. .
Thanks alot to hear this warning not serious. I accept your reason. Because I have not line 520.
PostPosted: Sun Mar 15, 2009 1:40 pm     Reply with quote
You probably have 519 lines. There are some messages that are generated after the whole file is compiled, and it gives you the last line instead of the offending one. Not sure why. Sometimes the line is in an #included file, or the include affects the numbering.
Barry
