fix time for the interrupt
viknes1985
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Wed Mar 11, 2009 2:50 pm     Reply with quote
hi,
i've some problem with interrupt. This what i wanted, i enable the interrupt, after it execute for X times, i disable it. So first i used a while loop to wait till the interrupt to be finish.
#int_RB
void reader(void)
     if (detector==0)
      //set timer1
      detector++;  //detector =1
     else if (detector == 1)
       //set timer1, pause timer1, run timer1, reset timer1
      //and some other code
      detector = 2;
     else if (detector == 2)
        //if fullfill the condition always execute the code in detector = 2
       if (got error)
       detector = 0;
       if (finish execute for x times)
        //disable interrupt
        flag = 1;
  enable_interrupts(global);
  while (1)
       flag = 0;
       RBIF = 0;
       RBIE = 1;
    while(!flag)
    //do nothing, wait for flag equals 1
   RBIE = 0;
    if(flag == 1)
    //printf at here
i've timers in ISR which is running and stopping according to if and else condition. it seems like it take very long time to execute, basically i'm doing a manchester code reader, the codes are at http://www.ccsinfo.com/forum/viewtopic.php?t=38065&highlight=.
Getting the code should only take about less than 50 ms, so i replace
while(!flag)
to
delay_ms(50)
still i couldn't get it run. Is it possible to idle the other process for 50ms and only run ISR. Or RTOS or HIGH priority is the only option i've? Thanks in advance
curious how to solve
how to solve it
PostPosted: Sat Mar 14, 2009 1:50 am     Reply with quote
Anyone know how to solve it?
Sydney
PostPosted: Sat Mar 14, 2009 3:38 am     Reply with quote
You need to post a test program that will compile and run, exactly what it should do, and what the problem is. It looks like a bit of a sideways approach to a simple task to me.
