Muppet Guest
| LCD |
Posted: Thu Mar 05, 2009 1:12 pm |
Hi
I have been a bit of a muppet and have connected my PIC to my LCD display using the DB0-DB3 data bits not DB4-DB7 as I should have. I have tried using the flexible LCD driver and just put in the pin definitions but no luck. Is it possible to use these pins and force it to work or am I going to have to use some messy jumpers to sort this out?
I am using a PIC18F4520, Batron 20x4 display. Compiler version 4.057.
Thanks for any advice. |
Posted: Thu Mar 05, 2009 1:18 pm |
See the LCD controller data sheet, on page 8, regarding pins DB0-DB3:
http://www.sparkfun.com/datasheets/LCD/HD44780.pdf
| Quote: |
DB0 to DB3 --
Four low order bidirectional tristate data bus pins.
Used for data transfer and receive between the
MPU and the HD44780U.
These pins are not used during 4-bit operation.
You will have to fix the board. |
Muppet Guest
Posted: Fri Mar 06, 2009 8:21 am |
Thanks PCM, have sorted that out its no messy but connected to the right pins, but I cant seem to get it to work still. I have checked all the connections and everything is fine. I am using DB4-DB7 connected to RB1-RB4, and D0-D2 connected to RS,RW,E respectively. Am using your flexible driver and have set the pins. I am using the BTHQ42003AV-FSTF-LED from farnell. If I leave it running sometimes all the segments go black and you can just about see different segments changing but its not characters just blocks and bits of blocks.
I am new to this and can't work out whats wrong any help would be much appreciated. |
treitmey
Posted: Fri Mar 06, 2009 8:37 am |
Muppet Guest
Posted: Fri Mar 06, 2009 2:46 pm |
Here is the data sheet for the BTHQ42003AV-FSTF-LED:
http://www.farnell.com/datasheets/47112.pdf
It's a 4x20 LCD with an LED backlight.
1. Check the connections. Trace them out carefully on the board. Then
post a list of the pin connections between the PIC and the LCD. The
typical case is, one of the connections is wrong.
2. This LCD uses the HD66712 controller. That controller has a
different set of starting addresses for the rows than the typical LCD.
The Flex driver has some #define statements for these row addresses.
You need to uncomment them, and comment out the normal ones
to make this LCD work. |
Muppet Guest
Posted: Fri Mar 06, 2009 7:46 pm |
Thanks PCM, I checked all connections by toggling the pin and checking the output, turned out I had a via on my board not soldered properly and RS was floating, so it now works....ish.
I am using the lines addresses for the HD66712U but it doesn't seem to be right, I get | Quote: | This is the 1st Next
1st Next is the 2nd
This is the 3rd line
3rd lineFinally the |
Using the other addresses I get | Quote: | This is the 1st line
1st lineThis is the
Next is the 2nd line
2nd lineFinally the |
Is this just a case of the wrong addresses or is it something else. It seems strange that I get a different first line when using the same address  |
Muppet Guest
Posted: Fri Mar 06, 2009 9:02 pm |
Have looked at it some more and it seems that the last 8 bits of lines 1 and 3 are copied to the first 8 bits of lines 2 and 4. I have tried changing the address to | Code: | //Custom
#define LCD_LINE_1_ADDRESS 0x00
#define LCD_LINE_2_ADDRESS 0xC
#define LCD_LINE_3_ADDRESS 0x40
#define LCD_LINE_4_ADDRESS 0x4C |
but it then seems to do the reverse, I get | Quote: | This is the Next is
This is the Finally
Finally the 4th line |
Any ideas as to what is going on? |
Muppet Guest
Posted: Tue Mar 10, 2009 11:14 am |
| I still can't sort this out , any help would be much appreciated. |
Posted: Tue Mar 10, 2009 1:05 pm |
This post explains what to do:
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=printview&t=12851&start=0
To implement those suggestions, add the 3 entries shown in bold below
to the init string:
| Quote: | int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Set mode: 4-bit, 2+ lines, 5x8 dots
0xc, // Display on
1, // Clear display
6, // Increment cursor
0x2c, // Enable writing to Ext. register
0x09, // Enable 4-line display
0x28 // Disable writing to Ext. register
See if that makes it work. |
Posted: Tue Mar 10, 2009 1:49 pm |
PCM programmer you are a legend I could kiss you
It works a treat. Just in case others read this I changed
| Code: | | int8 const LCD_INIT_STRING[7] = |
thanks again |
