| A2D Conversion Not working |
Posted: Mon Mar 02, 2009 11:13 am |
I cant get my analog to digital conversion working for PIC18F4520. Im watching "value" in MPLAB and it stays at zero.
| Code: | #include <18F4520.h>
#device adc=10
#FUSES INTRC //Internal RC Osc
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#include <float.h>
#include <math.h>
#include <stdio.h>
int16 value;
setup_adc_ports(AN0_TO_AN1|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_32 );
setup_psp(PSP_DISABLED);
setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_16);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(OSC_4MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
While(1)
set_adc_channel(0);
delay_us(100);
value=read_adc();
Im trying to read a variable pot attached to A0. |
andreluizeng
Posted: Mon Mar 02, 2009 11:39 am |
If you are not external supplying the ADC clock you need to configure the internal clock to work
try changing
by
and make sure that your pic is working, try blink some LED, because Im not comfortable with some used fuses like:
it sometimes can cause serious conflicts with another internal peripherals.
regards
André _________________ Andre |
Posted: Mon Mar 02, 2009 11:54 am |
| Replaced origonal with setup_adc(ADC_CLOCK_INTERNAL); Tested blinking LED with success. Still "value is reading zero". Using the watch function in the view menu of MPLAB. |
andreluizeng
Posted: Mon Mar 02, 2009 12:03 pm |
are you sure that read_adc makes the desired pin connected to the adc channel as input ??? if not... try setting up your port A pins as input (set_tris function)
regards _________________ Andre |
Posted: Mon Mar 02, 2009 12:04 pm |
Are you running this in the MPLAB simulator, or with an ICD2 debugger ?'
How are you testing this ? What board are you using ? |
Posted: Mon Mar 02, 2009 12:24 pm |
I have a ICD3 and after reading what u said I outputted my "value" through rs232 to computer and I'm getting different numbers when I change the pot so for now i will assume its working . Also I am just using a standard breadboard for all my hookup including chip. I don't think I was using the "watch" feature in MPLAB correctly. Now that I'm getting values out I want to translate that into a voltage. Here my calcs:
10 bit ADC so resolution is (Vdd/2^10) to get voltage just multiply that by my value stored in value. Correct? |
andreluizeng
Posted: Mon Mar 02, 2009 12:29 pm |
yes... it is correct.
regards. _________________ Andre |
Posted: Tue Mar 03, 2009 8:35 am |
Ok I found that I had a couple things incorrect when I was displaying the value. Here is my modified code:
int16 value;
float voltage;
setup_wdt(WDT_OFF);
setup_vref(FALSE);
While(1)
set_adc_channel(0);
delay_us(100);
value=read_adc();
voltage=(value*.00494624); //if i use value*(5/1023); it will display 0 on printout.
//voltage=(value*(5/1023)); //if i use value*(5/1023);
printf("total %lx voltage %lf \r\n",value, voltage);
Questions:
1. Why doesn't the second voltage calculations where i divide only display 0's?
2. Does anyone know where to find the information found in the printF statement such as %lx,%lf I search the forums to get them and I am wondering if there is a good place to find them. I check the maunual and didn't see them. |
andreluizeng
Posted: Tue Mar 03, 2009 8:46 am |
you need to "tell" that you are treating with float numbers, or else you only will take 0'z
try
voltage=(value*(5.0/1023));
or
voltage=(value*( (float)5/ (float)1023));
