filjoa
| write in eeprom question |
Posted: Fri Feb 27, 2009 4:58 pm |
Hi
Someone can help to correct this program?
I use PIC18F452 at 20Mhz
It don't have any errors but my problem is... it stay write correct in eeprom?
I need save STATE variable if power turnoff or if I make reset CPU.
int8 STATE;
void turnoff() //corte definitivo de igniçao
int8 hb,oldip;
int16 time;
oldip=0;
hb=0;
STATE=1;
output_low(GREEN);
output_high(RED);
write_eeprom(0, STATE);
output_high(R2);
output_low(R2);
do {
if ((input(PBREAK)==1) && (input(SENSOR)==1))
if (input(HBREAK)==1)
oldip=1;
hb++;
else oldip=0;
delay_ms(10);
time++;
}while (time<=700); //esquivalente +- a 9sec
if (hb==3)
STATE=0;
time=0;
hb=0;
reset_cpu();
}else
STATE=1;
time=0;
hb=0;
reset_cpu();
int8 start,door;
STATE=0;
door=0;
correct=0;
output_low(RED);
output_low(GREEN);
While(TRUE)
//STATE==1 circuito electrico curtado
//STATE==0 circuito electrico ligado
STATE = read_eeprom(0);
if (STATE==1) turnoff();
if (STATE==0) correct==0;
if(correct==0)
do {
start=input(IGN);
}while(start!=1);
readcode();
if (correct==1)
output_high(GREEN);
do {
door=input(DOORS);
start=input(IGN);
}while((door!=1 || start!=1));
if (correct==0)
output_high(PIN_C5);
fstop();
Sydney
Posted: Fri Feb 27, 2009 5:36 pm |
Your code enters an infinite loop here:
| Code: | while(TRUE)
do {
oldip=1;
hb++;
else oldip=0;
delay_ms(10);
time++;
You need to remove the while(TRUE) ala:
| Code: | do {
oldip=1;
hb++;
else oldip=0;
delay_ms(10);
time++;
}while (time<=700); //esquivalente +- a 9sec |
filjoa
Posted: Sat Feb 28, 2009 11:46 am |
thanks I don´t see that :D
now I stay test my program with prototipe but I have some problems..
in this part:
| Quote: |
int8 STATE; //variavel que vai dizer o estado do carro
int8 correct; //codigo correcto
void readcode()
int16 time;
int count,oldip,d;
count=0;
time=0;
oldip=input(SENSOR);
do {
d=input(DOORS);
}while(d!=0);
delay_ms(2000);
do {
d=input(DOORS);
}while(d!=0);
output_high(PBREAK);
do {
if (input(SENSOR) == 1)
if (oldip==0)
oldip=1;
count++;
oldip=0;
delay_ms(10);
time++;
}while (time<=1500);
if (count==3)
time=0;
count=0;
correct=1;
if (count!=3)
time=0;
count=0;
correct=0;
int8 start,door;
STATE=0;
door=0;
correct=0;
output_low(RED);
output_high(GREEN);
While(TRUE)
STATE = read_eeprom(0); STATE
if(correct==0)
do {
start=input(IGN);
}while(start!=1);
readcode();
if (correct==1)
output_high(GREEN);
do {
door=input(DOORS);
start=input(IGN);
}while((door!=1 || start!=0));
if (correct==0)
output_high(RED);
fstop();
after program call function readcode(); and I click on sensor 3 times on SENSOR (I confirm thar with output_high/low and an led in "if (count==3)"), I think how program continue in function main I go to "if (correct==1)" and stay on "do" cicle...
but I test this with leds and it after readcode(); it go direct for if(correct==0).
some one can explain me why?
kind regards |
Sydney
Posted: Sat Feb 28, 2009 12:20 pm |
I noticed another error too:
| Code: | | if (STATE==0) correct==0; |
Should be:
| Code: | | if (STATE==0) correct=0; |
No sure whether its causing your problem or not, but it maybe. |
filjoa
Posted: Sat Feb 28, 2009 7:21 pm |
Hi
thanks for this correction, I don´t see that...
but my stupid error stay there
| Quote: |
if (count==3)
time=0;
count=0;
correct=1;
if (count!=3)
time=0;
count=0;
correct=0;
I put count=0 in 1º "if" and it go into 2ª "if" because in this time count dosen't 3 but 0 :D
I continue my debug and if I have more problems I write there.
regards |
Sydney
Posted: Sun Mar 01, 2009 3:04 am |
Oops yes 2nd statement should be else-if. All you really need to do is:
| Code: | if(count == 3)
correct = 1;
correct = 0;
time = 0;
count = 0; |
filjoa
Posted: Sun Mar 01, 2009 7:03 am |
Hi
I find oder bug
| Quote: |
do {
door=input(DOORS);
start=input(IGN);
}while((door!=1) || (start!=0));
this cycle stay work as "AND" but I think how "||" is an "OR" correct?
for I can out of this cycle I need put "door" in 5V and "start" in 0V at same time...
I try test that:
| Quote: |
do {
door=input(DOORS);
start=input(IGN);
if(door==1) aux2=1;
if(start==0) aux2=1;
}while(aux2!=0);
aux2=0;
but this way program only make this cicle one time.
I test connection and I have on DOORS->0V and IGN->5V
some ideias? |
Sydney
Posted: Sun Mar 01, 2009 2:55 pm |
aux2=0;
do {
door=input(DOORS);
start=input(IGN);
if(door==1) aux2=1;
}while(aux2==0); |
The first code doesn't work because you need to use &&, then as soon as door==1 OR start==0 the loop exits.
| Code: | | }while(door!=1 && start!=0); |
It seems backward because you know when you want the loop to exit, but are writing a statement to keep it running. |
filjoa
Posted: Mon Mar 02, 2009 7:03 am |
Hi
thanks Sydney oder eyes see better
other problem:
void readcode()
int16 time;
int count,oldip,d;
count=0;
time=0;
do {
d=input(DOORS);
}while(d!=0);
output_high(PIN_B1);
do {
if (oldip==0)
oldip=1;
count++;
oldip=0;
delay_ms(10);
time++;
}while (time<=1500); //esquivalente +- a 20sec
if (count==3)
count=0;
time=0;
correct=1;//#### CODIGO CORRECTO #############
time=0;
count=0;
correct=0;
int8 start,door;
STATE=0;
correct=0;
output_low(RED);
output_high(GREEN);
While(TRUE)
if(correct==0)
do {
start=input(IGN);
}while(start!=1);
readcode();
if (correct==1)
output_high(GREEN);
do {
door=input(DOORS);
start=input(IGN);
output_low(PIN_B1);
output_low(PIN_B1);
[b]readcode();[/b]
if (correct==0)
output_high(RED);
fstop();
problem now is ... why when readcode() function is called for the 2ª time and I press SENSOR 3 times don't work? it return correct=0 and got to "if (correct==0)"
Oder problem stay on EEPROM Write...
when on turnoff() function I have "STATE=0;" and "write_eeprom(0, STATE);" when I make "reset_cpu();" I program start on main() funtion I have
| Quote: |
after that my program don't go to "turnoff()" function it continue normaly in order...
someone know where stay the problem?
regards |
Sydney
Posted: Mon Mar 02, 2009 10:31 am |
Its hard to see how you want it to work?
It looks like you need to press SENSOR 3 times, every time readcode() is called for the red light not to come on.
Your program seems overcomplicated, for what it needs to do. |
filjoa
Posted: Mon Mar 02, 2009 10:51 am |
hi
look only main and readcode function:
| Quote: |
void readcode()
int16 time;
int count,oldip,d;
count=0;
time=0;
do {
d=input(DOORS);
}while(d!=0);
output_high(YELOW);
do {
if (oldip==0)
oldip=1;
count++;
oldip=0;
delay_ms(10);
time++;
if (count==3) //exclusivamente 3 vezes
count=0;
time=0;
correct=1;
time=0;
count=0;
correct=0;
int8 start,door;
STATE=0;
output_low(RED);
output_high(GREEN);
While(TRUE)
if(correct==0)
do {
start=input(IGN);
}while(start!=1);
readcode();
if (correct==1)
do {
door=input(DOORS);
start=input(IGN);
output_low(YELOW);
readcode();
if (correct==0)
output_high(RED);
output_low(YELOW);
fstop();
I start the program and it go to readcode() after I need put my code (press 3 times SENSOR) after that it wait for door=0 or start=1, when one of this occur it go to readcode() e the problem stay there...
I press 3 times SENSOR and when return of readcode() red light turn on.
my ideia is while I put correct code it never go to "if (correct==0)"...
PS: Sydney look at your pm box |
Sydney
Posted: Mon Mar 02, 2009 11:30 am |
| I dont see what the problem is, but if readcode() is returning correct==1 on the 1st call, then it should on the 2nd also |
