khalis
| Modbus (Procedures to decide the addresses of input etc) |
Posted: Wed Feb 18, 2009 8:38 pm |
I have been studied the given example in pic c compiler - master.c, slave.c and modbus.c ... can someone explain a little bit about on how to manipulate crc table and how we define the input registers, coils register..etc...
Thanks |
Posted: Thu Feb 19, 2009 4:05 am |
Why do you want to manipulate the CRC table? The polynomial is fixed by the MODBUS standard.
The address usage in the master example is obvious, I think, cause it's a parameter in the respective functions.
The slave example has a very simple address scheme, possibly not sufficient for a real application. But I think, you are able to see, that for each function code supported by the example, a comparison of the incoming packet's address field is performed, requiring a zero address high byte. You may want to use a conversion to a 16 Bit address and length in your code before, e. g.
| Code: | addr = make16(modbus_rx.data[0],modbus_rx.data[1]);
cnt = make16(modbus_rx.data[2],modbus_rx.data[3]); |
khalis
Posted: Thu Feb 19, 2009 7:02 pm |
Sorry about the CRC. It was my first thought when I saw that crc table. I thought it was some kind of memory map that we would used to store our data but I was wrong about that.
In modbus slave.c example there were codes that made took times to figure it out.
first
if(modbus_rx.data[0] || modbus_rx.data[2] ||
modbus_rx.data[1] >= 8 || modbus_rx.data[3] +
modbus_rx.data[1] > 8)
modbus_exception_rsp(MODBUS_ADDRESS, modbus_rx.func,
ILLEGAL_DATA_ADDRESS); |
second
| Code: | | modbus_read_holding_registers_rsp(MODBUS_ADDRESS,(modbus_rx.data[3]*2),hold_regs+modbus_rx.data[1]); |
Besides that, I like to create like (40001 - 40008) for input status and (40009 - 40017) for output status. It is possible?
I need your explanation. Thanks  |
Posted: Fri Feb 20, 2009 1:26 am |
The problem is, that the author of ex_modbus_slave didn't spend the time to write a general handling of 16-Bit register addresses. So the examples uses the low byte of the address field as address. I give you an example, how a 16-Bit address handling can look like (with the previous shown calculation of addr and cnt) :
| Code: | case FUNC_READ_HOLDING_REGISTERS:
if(addr >= ADDR_H || addr+cnt > ADDR_H || !cnt || cnt > 125)
modbus_exception_rsp(MODBUS_ADDRESS,modbus_rx.func,ILLEGAL_DATA_ADDRESS);
modbus_serial_send_start(MODBUS_ADDRESS, modbus_rx.func);
modbus_serial_putc(2*cnt);
for (i=0;i<cnt;i++,addr++)
data = get_db_val(addr);
modbus_serial_putc(make8(data, 1));
modbus_serial_putc(make8(data, 0));
modbus_serial_send_stop();
event_count++;
break; |
In this application, the complete register address range of 0 to ADDR_H is accepted by the slave, however it's mapped to internal data storage by get_db_val(), and it's returning meaningful data only for known addresses and zero for others. You may want to assert an exception for each undefined address, but I think, it's not necessary on read. |
