help me with this code
soulraven
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Mon Feb 16, 2009 4:27 pm     Reply with quote
Can you help me with this code. Now I show the temperature in one part and I may want to associate each sensor with a certain variable separately. You have no idea how to do that?
// Returns 0 for one wire device presence, 1 for none
int8 ow_reset(void)
   int8 presence;
   output_low(DQ);
   delay_us(488);          // Min. 480uS
   output_float(DQ);
   delay_us(72);           // Takes 15 to 60uS for devices to respond
   presence = input(DQ);
   delay_us(424);          // Wait for end of timeslot
   //printf(lcd_putc, "\fPresence= %i", presence);
//delay_ms(500);
   return(presence);
// Read bit on one wire bus
int8 read_bit(void)
   output_low(DQ);
   delay_us(1);         // 1uS min. Original code relied on 8051 being slow
   output_float(DQ);
   delay_us(20);        // Wait at least 15mS from start of time slot
   return(input(DQ));   // Delay to finish time slot (total 60 to 120uS)
} // must be done next.
void write_bit(int8 bitval)
   output_low(DQ);
   if(bitval == 1) {
      output_float(DQ);
   delay_us(105);       // Wait for end of timeslot
   output_float(DQ);
int8 read_byte(void)
   int8 i;
   int8 val = 0;
   for(i=0;i<8;i++)
      if(read_bit()) val |= (0x01 << i);
      delay_us(120);  // To finish time slot
   return val;
void write_byte(int8 val)
   int8 i;
   int8 temp;
   for (i=0;i<8;i++)
      temp = val >> i;
      temp &= 0x01;
      write_bit(temp);
   delay_us(105);
// One wire crc
int8 ow_crc(int8 x)
   dowcrc = dscrc_table[dowcrc^x];
   return dowcrc;
// Searches for the next device on the one wire bus. If there are no more
// devices on the bus then false is returned.
int8 Next(void)
   int8 m = 1;             // ROM Bit index
   int8 n = 0;             // ROM Byte index
   int8 k = 1;             // Bit mask
   int8 x = 0;
   int8 discrepMarker = 0;
   int8 g;                 // Output bit
   int8 nxt;               // Return value
   short flag;
   nxt = FALSE;            // Reset next flag to false
   dowcrc = 0;             // Reset the dowcrc
   flag = ow_reset();
   if (flag||doneFlag)     // If no parts return false
      lastDiscrep = 0;     // Reset the search
      return FALSE;
   write_byte(0xF0);       // Send SearchROM command
   do
      x = 0;
      if (read_bit() == 1)
      x = 2;
      delay_us(120);
      x |= 1;   // And it's complement
      if (x == 3)                   // There are no devices on the one wire bus
         if (x > 0)                 // All devices coupled have 0 or 1
            g = x >> 1;             // Bit write value for search
         // If this discrepancy is before the last discrepancy on a previous
         // Next then pick the same as last time.
            if (m < lastDiscrep)
               g = ((Rom_Bit[n] & k) > 0);
            // If equal to last pick 1
               g = (m == lastDiscrep);  // If not then pick 0
               // If 0 was picked then record position with mask k
               if (g == 0) discrepMarker = m;
         // Isolate bit in Rom_Bit[n] with mask k
         if (g == 1)
         Rom_Bit[n] |= k;
         Rom_Bit[n] &= ~k;
         write_bit(g);  // ROM search write
         m++;           // Increment bit counter m
         k = k << 1;    // and shift the bit mask k
         // If the mask is 0 then go to new ROM
         if (k == 0)
         {  // Byte n and reset mask
            ow_crc(Rom_Bit[n]);      // Accumulate the crc
            n++;
            k++;
   } while (n < 8);  // Loop through until through all ROM bytes 0-7
   if (m < (65||dowcrc))   // If search was unsuccessful then
      lastDiscrep = 0;     // reset the last Discrepancy to zero
   else  // Search was successful, so set lastDiscrep, lastOne, nxt
      lastDiscrep = discrepMarker;
      doneFlag = (lastDiscrep == 0);
      nxt = TRUE; // Indicates search not yet complete, more parts remain
   return nxt;
// Resets current state of a ROM search and calls Next to find the first device
// on the one wire bus.
int8 First(void)
   lastDiscrep = 0;
   doneFlag = FALSE;
   return Next(); // Call Next and return it's return value;
void FindDevices(void)
   int8 m;
   if(!ow_reset())
      if(First())    // Begins when at least one part found
         numROMs = 0;
         do
            numROMs++;
            for (m=0;m<8;m++)
               FoundROM[numROMs][m] = Rom_Bit[m];   // Identifies ROM no. on device
            //printf("Device No.%u address ",numROMs);
         printf(lcd_putc,"%d  ",Rom_Bit[m]);
      //   printf(lcd_putc, "\f%X%X%X%X%X%X%X%X",
      //   FoundROM[numROMs][7],FoundROM[numROMs][6],FoundROM[numROMs][5], \
      //   FoundROM[numROMs][4],FoundROM[numROMs][3],FoundROM[numROMs][2], \
      //   FoundROM[numROMs][1],FoundROM[numROMs][0]);
   //   delay_ms(100);
   printf("%X%X%X%X%X%X%X%X\n\r",
         } while (Next() && (numROMs<10));   // Continues until no additional
                                             // devices found.
   printf(lcd_putc, "\fno ROM found");
         //delay_ms(500);
   printf(lcd_putc, "\fno ROM found2");
         //delay_ms(500);
   //putc('\n'); putc('\r');
// Sends Match ROM command to bus then device address
int8 Send_MatchRom(void)
   int8 i;
   if (ow_reset()) return FALSE;          // 0 if device present
   write_byte(0x55);                      // Match ROM
   for (i=0;i<8;i++)
      write_byte(FoundRom[numROMs][i]);   // Send ROM code
   return TRUE;
//read temperature from one wire DS18B20 sensors
//// de aici incepe citirea senzorilor si afisarea
void ReadTemp(void)
   int8 i;
      signed int16 stemp16;   // Raw temperature data in 2's complement
      int8 scratch[10];       // Lowest two bytes are for temperature
   float result=0;
   signed int16 temp;
         // If not using parasitic power can send the temperature convert
      // command to all DS18B20 and/or DS1822 devices on the bus.
      if (!ow_reset())     // If a device is present
         write_byte(0xCC); // Skip Rom command
         write_byte(0x44); // Temperature convert command
        // output_float(DQ);
         delay_ms(750);    // Max. conv. time is 750mS for 12 bit
         ow_reset();
         // Now get the device raw temperature data using Match ROM with the
         // addresses obtained with FindDevices().  Scale to deg. C, scaling is
         // 0.0625 (1/16) deg. C/bit with default 12 bit res. Could reduce res.
         // and therefore shorten conversion time if necessary.
         // Output the temperatures in whole degrees, apply rounding by adding
         // half denom.
         for (numRoms=1;numRoms<=4;numRoms++)
            if (Send_MatchRom())
               write_byte(0xBE); // Read scratch pad command
               dowcrc = 0;       // Reset the crc to start a new calculation
               for (i=0;i<=7;i++)
                   scratch[i] = read_byte();
                   ow_crc(scratch[i]);     // Accumulate the crc
               scratch[8] = read_byte();   // Received crc byte
               ow_reset();
               // If calculated crc from incoming bytes equal to crc byte
               // then data is valid. Calculate and output temperature.
               if (scratch[8] == dowcrc)
                  //stemp16 = (signed int16) make16(scratch[1],scratch[0]);
                 // stemp16 = (stemp16 + 8)/16;
                 // printf(lcd_putc, "\fTemp%i=%4ld ",numRoms, stemp16);
            //0.1 precision
            temp = make16(scratch[1],scratch[0]);
            result = (float) temp / 16.0; //0.1 deg C resolution
lcd_gotoxy(1,1);
printf(lcd_putc,"\nT%i= %3.1f \uC", numRoms, result);
//lcd_gotoxy(1,2);
//printf(lcd_putc,"\nT%i= %3.1f \uC", numRoms, result);
               else printf(lcd_putc,"\f Data error.");       // There was an error in the data
         printf(lcd_putc,"\f      Error      ");
         printf(lcd_putc,"\nSensors not found!");
         delay_ms(200);
