xlaz1078
| Simulate PIC24F - ISIS 7.4 -CCS, is possible? |
Posted: Sat Feb 14, 2009 10:15 am |
Hi, I'm new to PIC24, and before I buy some cards of development, I have tried to simulate the 24FJ64GA004 (EX_PinSelect.C - PCWHD 4.084) with ISIS PROTEUS 7.4 SP3. What I got many errors .
It is possible to use CCS PWD + ISIS + PIC24F?  |
leejok2003
Posted: Tue Feb 17, 2009 7:19 am |
Hi xlaz1078,
what kind of error you have there? |
xlaz1078
radioamator Guest
Posted: Fri Apr 17, 2009 3:28 pm |
hi
i have same problem with ccs and proteus when simulate my hex file with proteus this error"write 0xffff to unimplemented memory address 0x32a cause a trap"
i have this problem with mplab simulator too
anybody know solution for this problem
excuse me for bad english |
FvM
Posted: Fri Apr 17, 2009 3:58 pm |
If you expect any help, you should show the code lines causing the error trap.
P.S.: If I remember right, the said 0x32a error trap issue has been already discussed in the forum before. It's caused by erroneous SFR accesses of PCD built-in ADC functions. They are accessing register AD1PCFGH, that is only present with larger PICs. I found, that the bug is still present with PCD V4.090 and PIC64FJ64GA004. Cause an access to the register is used in chip setup, even with no ADC functions used in the code, I don't see an easy workaround. |
