multiple source files
JM35
PostPosted: Tue Feb 10, 2009 12:12 pm     Reply with quote
Hello !
How to compile with PCWHD (Version 4.073, 44201 ) multiple source files ???
Do I have a multiple compilation unit ? I can't use headers, PCWHD tell me blabla "Function used but not defined ..." !
In main.c :
#include "LCD.h"
In LCD.h :
#ifndef _H_LCD_
#define _H_LCD_
 // prototypes ...
In LCD.c :
// functions ....
I'm not using MPLAB. Just want to organize my code with 2 or 3 headers.
Thank's a lot !
PostPosted: Tue Feb 10, 2009 1:05 pm     Reply with quote
The traditional way of using multiple source files with CCS, is to #include
them all in the main source file. Then compile the main source file.
JM35
PostPosted: Tue Feb 10, 2009 3:11 pm     Reply with quote
Thank's !
That's exactly what I'm doing ...
#include "C:\Temp2\Stage PIC\TP\TP2_LCD\Corrige\test_lcd.h"
#include "C:\Temp2\Stage PIC\TP\TP2_LCD\Corrige\LCD.c"
   char msg[20] = {"Hello !"};
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   LCD_INIT();
   while(1){
   LCD_GOTO(6,2);
   LCD_PUT_STRING(msg);
   LCD_CLEAR();
In LCD.h :
#include "LCD.c"
#ifndef _H_LCD_
#define _H_LCD_
void LCD_INIT(void);
void LCD_SEND(char Octet, char INST_DATA);
void LCD_ENABLE(void);
void LCD_CLEAR(void);
void LCD_PUT_CHAR(char Car);
void LCD_PUT_STRING(char *ptr);
void LCD_GOTO(BYTE Col, BYTE Ligne);
In LCD.c :
#define LCD_EN       PIN_C5
#define LCD_RS       PIN_A5
#define INSTRUCT     0
#define CARACT       1
void LCD_INIT(void)
   // initialisation de l'afficheur LCD controlleur KS0066U
   delay_ms(40);                                         //30 ms d'après datasheet
   LCD_SEND(0x33,INSTRUCT); delay_ms(10);                // Mode 8 bits
   LCD_SEND(0x32,INSTRUCT); delay_ms(10);                // Mode 4 bits
   LCD_SEND(0x2C,INSTRUCT); delay_us(50);                // Display ON, Cursor OFF, Blink Off
   LCD_SEND(0x06,INSTRUCT); delay_us(50);                // Entry Mode Set : Increment Ram, No Shift Display
   LCD_SEND(0x0C,INSTRUCT); delay_us(50);
   LCD_CLEAR();
// etc ..... all others functions
What's the problem ????
JM35
PostPosted: Tue Feb 10, 2009 3:17 pm     Reply with quote
oops sorry, copy/paste error :
in main :
#include "C:\Temp2\Stage PIC\TP\TP2_LCD\Corrige\LCD.h"
in LCD.h :
#include "LCD.c"
in LCD.c :
test_lcd is my project ...
PostPosted: Tue Feb 10, 2009 3:23 pm     Reply with quote
In the CCS method, you don't include the header files such as test_lcd.h
in each module. Remember, it's effectively one big file.
If you have a header file which has constants which are used by other
include files, then just #include that header file one time, in the main
source file, near the top of the file.
JM35
PostPosted: Tue Feb 10, 2009 3:35 pm     Reply with quote
Thank you for your response !
So I try :
in main :
in LCD.h : nothing ?
in LCD.c
PCWHD don't compile ! Stop because didn't find lcd_init() !
PostPosted: Tue Feb 10, 2009 3:41 pm     Reply with quote
I don't know exactly what you're doing, because all your files have
similar sounding names. Smile
See my post in this thread. It shows how to organize your main source
file:
http://www.ccsinfo.com/forum/viewtopic.php?t=18649
JM35
PostPosted: Tue Feb 10, 2009 3:52 pm     Reply with quote
my project's name is test_lcd
the main file is test_lcd.c :
   setup_adc(ADC_OFF);
   setup_wdt(WDT_OFF);
   LCD_INIT();
   while(1){
   LCD_GOTO(6,2);
   LCD_CLEAR();
then only one header : LCD.h
and the associated source : LCD.c
// Broches du LCD :
#define INSTRUCT     0
#define CARACT       1
void LCD_INIT(void)
   LCD_CLEAR();
   // Génère une impulsion positive de 50 µs sur la broche EN du LCD
   // Le bus de données 4 bits est pris en compte par le LCD
   output_low(LCD_EN);                    // LCD désélectionné
   delay_us(1);
   output_high(LCD_EN);delay_us(100);       // LCD sélectionné
   delay_us(1);
   // Envoi l'octet Octet au LCD
   // Si INST_DATA = INSTRUCT => Envoi d'une instruction
   // Si INST_DATA = CARACT => Envoi d'un caractère à afficher
   output_bit(LCD_RS,INST_DATA);
   delay_us(50);
   // Envoi MSB de Commande au LCD :
   if((Octet>>4)& 0x01)output_high(PIN_B1); else output_low(PIN_B1);
   if((Octet>>5)& 0x01)output_high(PIN_B2); else output_low(PIN_B2);
   if((Octet>>6)& 0x01)output_high(PIN_B4); else output_low(PIN_B4);
   if((Octet>>7)& 0x01)output_high(PIN_B5); else output_low(PIN_B5);
   LCD_ENABLE();        // Valide la donnée 4 bits
   // Envoi LSB de Commande au LCD :
   if(Octet & 0x01)output_high(PIN_B1); else output_low(PIN_B1);
   if((Octet>>1)& 0x01)output_high(PIN_B2); else output_low(PIN_B2);
   if((Octet>>2)& 0x01)output_high(PIN_B4); else output_low(PIN_B4);
   if((Octet>>3)& 0x01)output_high(PIN_B5); else output_low(PIN_B5);
   LCD_ENABLE();
   delay_ms(1);     // 2 envois séparés par au moins 40 µs
   // Efface LCD, curseur retourne en haut à gauche
   LCD_SEND(0x01,INSTRUCT); delay_ms(2);            // > 1.53 ms
   // Affiche le caractère à la position courante du curseur
   LCD_SEND(Car,CARACT);
   // Affiche la chaine de caractères à la position courante du curseur
   while(*ptr)LCD_PUT_CHAR(*ptr++);
   // positionne le curseur Ligne, Colonne
   // Ligne = 1 ou 2
   // Col = 1 à 40
   BYTE address;
   if(Ligne<=1)address = 0; else address=0x40;
   address+=Col-1;
   LCD_SEND(0x80|address,INSTRUCT);
That's all !
PostPosted: Tue Feb 10, 2009 4:07 pm     Reply with quote
test_lcd.h
What's in this file ?
JM35
PostPosted: Tue Feb 10, 2009 4:18 pm     Reply with quote
Created by wizard !
#include <18F452.h>
#device ICD=TRUE
#device adc=8
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
I don't modify it ...
PostPosted: Tue Feb 10, 2009 4:23 pm     Reply with quote
Your lcd.h file has the function prototypes it in. The compiler needs to
see them before it sees any calls to the functions. All you need to do to
fix it, is to change the order of your #include statements so the lcd.h
file comes before the .c file. Example:
#include "test_lcd.h"
#include "LCD.h"
#include "LCD.c"
PostPosted: Tue Feb 10, 2009 4:25 pm     Reply with quote
#FUSES LVP
Also, change this to NOLVP. Do that in all your programs. You're not
using low voltage programming mode.
JM35
PostPosted: Tue Feb 10, 2009 4:32 pm     Reply with quote
OK thank's a lot it's working fine now !
I suppose it's the same way if I need more header files ...
Not a very standard C !
Bye and thank you !
