How to use timer
wa1384
How to use timer
PostPosted: Wed Feb 04, 2009 1:00 am     Reply with quote
I would like to ask about how to use the timer too...
how to use set_timer0, get_timer0,
what is the meaning of the value of set_timer0(0)...
because I am doing a program that will have a digital waveform, which have high and low voltage...I would like to use timer to make the waveform low for a certain time..anybody can help me on this?
thanks in advance...
wa1384
PostPosted: Wed Feb 04, 2009 1:03 am     Reply with quote
sorry,forgot to put some info, I am using PIC16f877A
PostPosted: Wed Feb 04, 2009 2:01 am     Reply with quote
Look at Newguy's timer tutorial in the Code Library forum:
http://www.ccsinfo.com/forum/viewtopic.php?t=22467
Additional info:
Microchip -- Timers Tutorial
http://ww1.microchip.com/downloads/en/DeviceDoc/51682A.pdf
Microchip -- Timers: Timer0 Tutorial (Part 2)
http://ww1.microchip.com/downloads/en/DeviceDoc/51702A.pdf
wa1384
PostPosted: Wed Feb 04, 2009 8:56 pm     Reply with quote
If I have this kind of program,
int s1;
int s2;
int s3;
int s4;
   setup_adc_ports(AN0);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
  setup_timer_0(RTCC_INTERNAL|RTCC_8_BIT|RTCC_DIV_256);
 // setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
  while (read_ADC()>50);
  while (read_ADC()<50);
  delay_ms(125);
  s1=read_ADC();
  printf("\rADC=%u,s1",s1);
  delay_ms(250);
  s2=read_ADC();
  printf("\rADC=%u,s2",s2);
  delay_ms(250);
  s3=read_ADC();
  printf("\rADC=%u,s3",s3);
  delay_ms(250);
   s4=read_ADC();
   printf("\rADC=%u,s4",s4);
  set_timer0(4);
  while ( get_timer0() ) ;
  output_low(PIN_D0);
  output_low(PIN_D1);
  output_low(PIN_D2);
  if  ((s1>50 && s1<126) && s2<50 && s3<50 && s4<50)   //case1
  output_high(PIN_D0);
  output_low(PIN_D1);
  output_low(PIN_D2);
else if  ((s1>50 && s1<126)  && (s2>50 && s2<126) && s3<50 && s4<50 )      //case2
  output_low(PIN_D0);
  output_high(PIN_D1);
  output_low(PIN_D2);
else if ((s1>50 && s1<126) && (s2>50 && s2<126) && (s3>50 && s3<126) && s4<50)       //case4
  output_low(PIN_D0);
  output_low(PIN_D1);
  output_high(PIN_D2);
 else if ((s1>126 && s1<176) && (s2>50 && s2<126) && s3<50 && s4<50)       //case3
  output_low(PIN_D2);
else if ((s1>126 && s1<176) && (s2>50 && s2<126) && (s3>50 && s3<126) && s4<50)       //case5
  output_low(PIN_D1);
else if ((s1>126 && s1<176) && (s2>126 && s2<176) && (s3>50 && s3<126) && s4<50)      //case6
  output_low(PIN_D0);
else if (s1>176 && (s2>126 && s2<176) && (s3>50 && s3<126) && s4<50)    // case7
 else                           //case0
  output_low(PIN_D0);
  output_low(PIN_D1);
  output_low(PIN_D2);
I want the output of pin_D0 to pin_D2 to be low after running 7ms, but it is not working. Is it because of my wrong calculation?
My crystal frequency was 4 MHz, 8 bit counter.
PostPosted: Wed Feb 04, 2009 11:25 pm     Reply with quote
Why don't you just do this:
delay_ms(7);
output_low(PIN_D0);
output_low(PIN_D1);
output_low(PIN_D2);
Make everything as simple as possible.
wa1384
PostPosted: Thu Feb 05, 2009 1:37 am     Reply with quote
thanks for the reply, but my mean is, I want to make the output low after all the if else things happen...but I did try the suggestion given, did not work out...
anyway, if I want to use interrupt
timer0_isr(void)
output_low(PIN_D0);
output_low(PIN_D1);
output_low(PIN_D2);
how to call it? I enabled the interrupt already but it says function not void and doesn't return value timer0_isr...
thanks again in advance
PostPosted: Thu Feb 05, 2009 5:07 am     Reply with quote
You don't call it.
That is the whole point of interrupts. The _event_ calls it.
You need to declare an interrupt handler like:
#int_timer0
void timer0_isr(void) {
   output_low(PIN_D0);
   output_low(PIN_D1);
   output_low(PIN_D2);
   disable_interrupts(INT_TIMER0); //explain this later...
The interrupt handler, can never return a value, or receive a value. If you want to pass things to/from a handler, you do this through global variables. The compiler will complain if you try to return a value.
The handler _must not_ be 'called' by any of your code.
Then if the interrupts are enabled, the handler will _automatically_ be called when the event occurs.
Now, you have not posted your clock statement, so we can't tell how fast your timer would 'tick'. However it counts from the master oscillator/4, divided by the selected prescaler (/256 as you show). So if your master clock was 10MHz, it'd count one every (10000000/(4*256)) = 102.4uSec.
So 68 counts, would give 6.96mSec. The closest you could get with this prescaler.
Then to make the event 'happen', you would want:
void fire_in_seven(void) {
    set_timer0(256-68);
    clear_interrupts(INT_TIMER0);
If you call this, the output pattern you want, will occur automatically 6.96mSec latter, while your other code can be carrying on doing whatever you want. I have disabled the interrupt in the handler, since otherwise the pattern will trigger again 26msec later, when the interrupt fires again. You will need to adjust the counts to suit your clock.
Now, the 'clear' is necessary, since otherwise the interrupt will trigger immediately, if it has triggered since the last time the routine was used, or since the chip started.
wa1384
PostPosted: Mon Feb 23, 2009 2:40 am     Reply with quote
So, If I use 20Mhz for the master clock, and I if I want all pin low in 1ms delay, I must use a 4 of prescaler right? and for the timer what should I set it?
