Andrew83
| How to handle strings with state machine ?-Reloaded |
Posted: Sun Jan 25, 2009 6:16 am |
Hello 2 all !
Fist of all :
- pic18f452
-10MhZ
-CCs C ver. 4.057.
Let's say i have a string like cmd[].
I want to be able to go through this string and if a certain element is "1", make a led sequence like this (output_low for 1ms, output_high for 1ms), or if it's a "0" (output_high for 1ms, output_low for 1ms).
If i use the delay code function, it messes up the code.
Any ideas ?
How can i make this work without using delay ?
Here is my simple test code:
#include <18f452.h>
#use delay(clock=10000000)
char gc_COMMAND_timer;
char i=0;
char cmd[2]={'1','0'};
#bit TMR0IF = 0xFF2.2
#define COMMAND_TIMER_TICKS 4 // 4 ms
#define RTCC_PRELOAD 246
#int_rtcc
void rtcc_isr(void)
// Reload the RTCC, so it will keep overflowing every 10 ms.
set_rtcc(RTCC_PRELOAD);
// Decrement any timers that are running.
if(gc_COMMAND_timer)
gc_COMMAND_timer--;
void check_COMMAND()
if(gc_COMMAND_timer )
return;
gc_COMMAND_timer = COMMAND_TIMER_TICKS;
for(i=0; i<3; i++)
if (cmd[i]=='0')
output_low(pin_b0);
delay_ms(1);
output_high(pin_b0);
delay_ms(1);
delay_ms(1);
output_low(pin_b0);
delay_ms(1);
// Setup the RTCC.
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_BIT);
set_timer0(RTCC_PRELOAD);
enable_interrupts(INT_RTCC);
check_command();
Posted: Sun Jan 25, 2009 3:44 pm |
| Quote: | | If i use the delay code function, it messes up the code. | Can you be more specific and provide an example of what you mean? Now we have no clue as to what we should be looking for.
A few remarks on your code: | Code: | #define COMMAND_TIMER_TICKS 4 // 4 ms
#int_rtcc
void rtcc_isr(void)
set_rtcc(RTCC_PRELOAD); | The COMMAND_TIMER_TICKS is defined as 4ms, but the RTCC interrupt has a resolution of 10ms??? It should be either 1ms RTCC interrupt or 40ms for the COMMAND_TIMER_TICKS.
| Code: | | #define RTCC_PRELOAD 246 | With this setting you are now generating interrupts at a rate of:
(256 - 246) * 4 * 256 prescaler / 10MHz = 1ms
This loops three times, not two. You are processing the non existing command cmd[2] and total execution takes 6ms which is longer than your 4ms COMMAND_TIMER_TICKS. |
Andrew83-guest Guest
Posted: Mon Jan 26, 2009 12:52 am |
Hello ckielstra !
Ok...so:
1.This code that I've posted is the code for a state machine. Basically it's the code for 1 state of the 4 that I have. I'm using a Oshon simulator to verify that the program is working. The delay should be 1 ms but instead it is about 500 uS.
I know that I shouldn't use the delay function in a state machine, but how else can I make the timed sequence work ?
2. The interrupt triggers every 1 ms. The comment is wrong and I apologize for that.
3. You are right also about the for loop. Yes...it is for 3 elements, and I declare only two, so thanks for pointing out this small (but critical) error. |
Posted: Mon Jan 26, 2009 12:55 am |
And again ...thank's you 4 your time !
I really need to get this sorted to get things moving in the right dirrection! |
Posted: Mon Jan 26, 2009 3:16 am |
Some further comments:
Could you use a pin that is controllable by the CCP, for the signal you want to pulse?. The CCP, supports modes other than the simple PWM, and one of these allows a pin to be 'set' at a particular count, and another allows the same pin to be cleared at a count. There is a CCP interrupt at the same time. So what you could do, is in the original interrupt, set the pin, and program the CCP to clear it in 1mSec. Then when you get this CCP interrupt, program it to set it in another mSec. This way the hardware will do the pulsing, and you won't need to delay for it.
Second comment, do a search here about using multiple #use delay statements. Basically, though having a delay in the interrupt is 'nasty', it may be the simplest way to do what you want. The big problem it introduces though is that interrupts will then be disabled in the external code, whenever delays are called, which may cause problems. You can avoid this by adding a second #use delay statement. One for the 'interrupt' routines, and one for the main. The compiler then generates separate delay code for the interrupts,and doesn't have to tun off interrupts in the delays in the main.
Doublle check your crystal, and the settings in your simulator. The delay time is dependant on two things. The crystal, and the value in the #use delay statement. Basically, if the crystal was actually 20Mhz, and the delay statement was told it was 10MHz, you would see exactly half the required delay. Most simulators, have their own 'clock' value, that has to be set separately. It sounds as if yours is running at 20MHz.
Wayne_
Posted: Mon Jan 26, 2009 5:33 am |
The only solution I can think of is to put a state machine in your ISR.
Set your ISR to interrupt ever 1ms (if possible)
#define COMMAND_TIMER_TICKS 40 // 40 ms
#define MAX_CMD_SIZE 2
char cmd[MAX_CMD_SIZE] = {'1','0'};
int state = 0;
int cmdIndex = 0;
#int_rtcc
void rtcc_isr(void)
// Reload the RTCC, so it will keep overflowing every 1 ms.
gc_COMMAND_timer--;
state = 1; // start cmd
switch(state)
case 0: // do nothing
case 1: // check next cmd
if (cmdIndex == MAX_CMD_SIZE)
cmdIndex = 0;
state = 0; // Finished
if (cmd[cmdIndex] == '0')
output_low(pin_b0);
state = 2; // low high
else if(cmd[cmdIndex] == '1')
state = 3; // hight low
cmdIndex++;
case 2:
state = 1:
case 3:
output_low(pin_b0);
state = 1:
Something like that.
Now your code has some discrepencies,
If the interrupt triggers every 10ms then your COMMAND_TIMER_TICKS will be a 40ms tick!
You say this is a statemachine but you don't actually show one!
Hope this helps. There may be issues with doing it this way I hope which others will point out.
Some explination,
The interrupt fires every 1ms.
After 40 40ms, start the cmd
If 0, set low then next tick high
if 1 set high then next tick low
next tick, next command |
Andrew83
Posted: Mon Jan 26, 2009 1:17 pm |
Hello !
Thank you for your quick answers !
Concerning Ttelmah's post i must make the following clarifications:
Your idea about using a PWM controlled pin to achieve the behavior i was looking for is very appealing. I will try this as soon as possible and get back to you with my results.
Another thing .... you said in your post :
| Quote: |
Second comment, do a search here about using multiple #use delay statements. |
I was faced with this kind of problem in another software, when interrupts where disabled because of a reentrancy problem caused by the use of delay function in an interrupt.
I've already tried to use multiple #use delay statements (as is mentioned in the FAQ of the compiler) but did not get the desired result until i've set a few flags in the isr and did the delay function in the main.
Can you please provide me with a thread where this problem was raised by someone else ? I'm sorry to ask you this but by searching this forum i've not been able to find any relevant threads.
Concerning Wayne_'s post :
Thank you 4 your interest. I will try your implementation. I kind'a makes sense....but...i'm sure there will be issues using a state machine inside a state machine. Anyway, i'll give it a try and let you know as soon as possible about the result!
Thank you everyone ! |
