24HJ128GP202 Compiler Doubt
pasini
PostPosted: Sun Jan 25, 2009 4:57 pm     Reply with quote
Hi, I'm using PIC24HJ128GP202, MPLAB 8.14 and CCS 4.084
I am new to 16bit MCU, but I have good knowledge of 8bits MCU and CCS compiler.
Since, PIC24 is a 16 bit compiler and from the datasheets, the statement set_tris_a(0b0000000000011111); is correct, isn't it ?
Moreover, interestingly when I try to separate my project into different .c source codes, the compiler gives me #DEVICE required error.
main.c is just
#include <24HJ128GP202.h>
#fuses HS, NOWDT
#use rs232(stream=GPS, baud=9600, parity=N, xmit=PIN_B15, rcv=PIN_B14, bits=8, stop=1) // RX1, TX1
#include "init.h"
#include "defines.h"
   InitMCU();
   set_tris_b(0b0101010010000111);
   {   LedOn();
      BuzzerOn();
      delay_ms(20);
      LedOff();
      BuzzerOff();
      fputc('U', GPS);
and init.c is
#include "init.h"
void InitMCU(void)
I wasn't really expecting this kind of error just because I have multiple files in the project. If I include the statement #device PIC24HJ128GP202 ADC=10 another error appears saying that I cannot change the device in that piece of code.
Where can I find some tutorial to use CCS with PIC24 ?
Thanks in advance,
Luiz
PostPosted: Sun Jan 25, 2009 8:06 pm     Reply with quote
The ADC #device statement needs to be right after the header include line:
#device ADC=10   <==== It goes here WITHOUT the Processor declaration
#fuses HS, NOWDT
As far as the TRIS statements go, unless you are in some really time critical
operations you don't need those lines, let the compiler take care of that
automatically for you. Besides, with the code you show you are using the TRIS statements twice in a row.
pasini
Error still there
PostPosted: Mon Jan 26, 2009 6:53 am     Reply with quote
I included the #device statement but the error is still there. The compiler says the error is in the init.h file ! Now files are like these:
#device ADC=10
#fuses HS, NOWDT
#include "init.h"
char ch;
#int_rda
void SerialInterrupt()
{    ch=fgetch(GPS);
   InitMCU();
   {   LedOn();
        delay_ms(20);
        LedOff();
        delay_ms(20);
init.h is just <<<<<------- #device needed error is here !!!!!
void InitMCU(void);
init.c is
#include "init.h"
void InitMCU(void)
       enable_interrupts(INT_RDA);
It doesn't matter if I leave blank lives of not at the beggining of init.h. The error is always in line #1 ( even if it's blank ).
If I include all functions in a single file, it compiles ok.
I think the error is not really the #device statement, but some other thing. The problem is really when I add files to the project. Can it be a CCS or MPLAB bug ?
Pasini
PostPosted: Mon Jan 26, 2009 8:49 am     Reply with quote
Are you still getting the "cannot change device" message? You don't show what is in defines.h but
make sure it has no #device or #include lines in it.
This should compile.
#device ADC=10
#fuses HS, NOWDT
//  #include "defines.h"
char ch;
#int_rda
{    ch=fgetch(GPS);
void InitMCU()
  InitMCU();
//        LedOn();
        delay_ms(20);
//       LedOff();
        delay_ms(20);
pasini
PostPosted: Mon Jan 26, 2009 10:54 am     Reply with quote
The way you write it, I can compile the code. But the problem is when I separate the code into multiple files, such as init.h init.c and so on.
My project will increase in size so I really would like to write the code in separate files to organize everything.
With #device option you wrote I do not receive the error.
Is there any setting or parameter I am missing ? Why can't I use multiple files ? I don't understand this...
Pasini
PostPosted: Mon Jan 26, 2009 1:21 pm     Reply with quote
I don't have the PCD compiler. But traditionally, CCS doesn't use a
linker and all files are added to the main source file with #include
statements.
In a normal C compiler such as MSVC, you can #include the same
header files in each module (file). That's standard. But in CCS you
don't do it. In other words, don't put these statements in every file:
#include "init.h"
You are putting them in main.c and in init.c. Just put them in the main.c source file only.
pasini
PostPosted: Tue Jan 27, 2009 7:22 am     Reply with quote
I updated to MPLAB 8.20 and CCS 4.085 but no way I can compile the files. I tought it could be Windows Vista but even with XP I cannot compile anything.
I am becoming upset with this problem :(
Pasini
PostPosted: Tue Jan 27, 2009 8:28 am     Reply with quote
OK Pasini,
When you compile what error are you getting and where?
Since the program I gave you works it is likely a syntax problem. After you remove all the duplicate includes as advised by PCM post a small program illustrating the problem so we can look at it and try to help.
pasini
PROBLEM SOLVED AND UNDERSTOOD !!!!!!!!!
PostPosted: Tue Jan 27, 2009 12:02 pm     Reply with quote
Hi all,
I solved the problem.
The thing is that I was including all the files in the project. As CCS answered me, I have to add the statment #include "abc.c" as a driver file in the main file. I do not need to include the file itself in the Source Files list.
I ( and others) shall do this:
main.c :
#fuses FRC, NOWDT
#use delay(clock=8000000)
#include "b.c"  // <<<<<<------ it's a <<.c>> file !!!!!
  MyFunc();
and
b.c :
void MyFunc(void)
  int8 c;
  for(c=0;c<10;c++);
Watch out !!! There are no function prototypes such as
void MyFunc(void);
in the .h file !!!!
I think (someone can confirm) that this is one of the reasons CCS is not an ANSI C compiler.
Now it works fine.
Thanks for any help
Pasini
