elellilrah
| i2c_read() on PIC 12F629 |
Posted: Wed Jan 21, 2009 9:40 am |
I am looking at using a PIC12F629 as a slave to do some very simple operations using the I2C bus for a display. However, the help in PCW 4.082 indicates that i2c_read() only works on chips with dedicated hardware. Is true? I've seen code snippits of I2C done with software mode on any many different processors and pins. I just want to verify that the i2c_read function will work.
Thanks! |
Posted: Wed Jan 21, 2009 4:14 pm |
They won't.
It is possible to write an I2C slave, without the hardware, but the CCS functions don't support this, and it really is processor intensive. You would not be able to do anything else on a 629, since the slave _must_ react in very tight timing windows, and even simple display functions would without hardware buffering be very hard to guarantee to finish in time.
I'm afraid that you would be much better off selecting a basic chip with I2C hardware.
I'd put the labour cost to do this reasonably well, to probably be in excess of the cost of 1000 'better' processors...
elellilrah
Posted: Wed Jan 21, 2009 11:54 pm |
| Ttelmah wrote: | They won't.
Thanks. It's strange, because I just found some code running on a 16F688 that has the following:
#use i2c(MASTER, sda=SDA_PIN, scl=SCL_PIN, FORCE_SW)
msb_byte = i2c_read(0);
that reads from EEPROMS using i2c_read(). The program seems to work perfectly, the i2c_read() works fine. So perhaps I have a chance of getting this to work? |
crystal_lattice
Posted: Thu Jan 22, 2009 12:40 am |
In your first post you said:
| Quote: |
| And now you say:
| Quote: |
...that reads from EEPROMS using i2c_read()
Ttelmah said it won't be viable to implement a I2C slave on the pic, as you querried in the first post. Your second post you are questioning the implementation of a I2C master. Which is it....? |
Posted: Thu Jan 22, 2009 3:33 am |
Spot on.
The key to understand, is that the _master_, controls the timings on the I2C bus. If it runs slow, or has to do something else, it doesn't matter. The bus just runs slow. However the slave, _must_ respond inside the timings being generated by the master (there is an ability to 'delay' the end of the response (clock stretching), but this already requires the slave to be responding, and have held the clock line low.
You can implement an I2C master on the 12F629, as easily as anything. A _slave_, is the hard bit.
Talking to an EEPROM as a master, with the 629, is 'easy'. There are probably several hundred examples here on chips similar to this, that will work fine. Receiving I2C as a slave, and writing it to a display, is a whole different 'can of worms'...
If (for instance), the bus is running at 100KHz, the slave device, has just 10uSec, in which it must either have read the data bit, or have held the clock line low.
crystal_lattice
Posted: Thu Jan 22, 2009 4:07 am |
| If you have to use the 629, you could buffer the incomming data and only after the complete receiption of a message, do the display function. The 629 can then have a ready flag which the master will have to poll before starting a transmission. |
crystal_lattice
Posted: Thu Jan 22, 2009 4:09 am |
I see Ttelmah has already mentioned buffering...  |
elellilrah
Posted: Thu Jan 22, 2009 4:39 pm |
| crystal_lattice wrote: | | If you have to use the 629, you could buffer the incomming data and only after the complete receiption of a message, do the display function. The 629 can then have a ready flag which the master will have to poll before starting a transmission. |
Sorry for the confusion between master and slave. I need to have my larger CPU (16F887) run as master and the 629 as a slave. Having the buffer receive the data, then displaying it makes sense. Having another line like chip select or ready flag is an even better idea. It would be helpful to keep the data transactions under control.
From what it sounds like I should move up to a 16F688 or the like for my smaller 629 CPU to do this job. That way I can have 3 pins for transaction control to set a ready flag, then SDA and SCL. If I issue a i2c_read() on the slave, then will the smaller CPU sit indefinitely until the master sends the byte across? Or is the CCS I2C slave programmed to time out as a slave read? |
zcashion Guest
Posted: Tue Oct 06, 2009 7:19 pm |
If you plan on using a third line for a chip select, then you should probably switch to SPI communication. Using a chip select pin circumvents the need for sending the address byte that is necessary with I2C.
As for your question on I2C_read. This command is dependent upon whether you are operating in Master or Slave mode. In Master mode it generates a clock. In Slave mode it waits indefinitely for a clock from the master. This is why there is an option to restart the watchdog timer in the #use i2c command.
Cheers |
rnielsen
Posted: Wed Oct 07, 2009 10:05 am |
Simply put, if you want to use a PIC as a slave then select one that has the hardware to support it. Otherwise, you're in for a very bad headache and loss of hair.
Ronald |
