| View previous topic :: View next topic   |
				| an oddity with ones complement or TTWIW? |
				 Posted: Mon Jan 19, 2009 9:38 am     |
				PCM ver 4.066
the ones complement seems odd - or perhaps its me
for the following simple case
unsigned int8 myvar=7;
myvar=~myvar;  // generates  COMF  assembler as desired
~myvar;      //
// and
~~myvar;   // generates NEITHER an error NOR the desired COMF opcode
//                    NO code produced at in the LST file   for either form
// meanwhile
myvar~;    // and
myvar~~; // both generate an error 'expecting ;'
is it ME or the compiler ??? |
				 Posted: Mon Jan 19, 2009 12:32 pm     |
				It wouldn't. You are not putting the result into a variable, so the optimiser removes the lines...
It is a bit like saying:
myval+1;
Again no code will be generated.
				 Posted: Tue Jan 20, 2009 9:26 am     |
				sorry - i guess i was stuck under the impression that  1's complementing was a unitary operation in the exact same category as ++var or --var,  which don't need a reassignment to work - since there is an underlying assembler, single cycle opcode for it .
 That and the lack of an error when i try ~~var .
i guess you are maybe saying TTWIW is the real answer, since there is no reason a compiler couldn't be made to recognize ~~ and treat it like ++, -- etc. |
			SherpaDoug
				 Posted: Tue Jan 20, 2009 12:49 pm     |
				What would you expect ~~var to do?  Would it be the same as ~(~var) which would do nothing?
 ++ and -- have clear meanings, but ~~ is not clear to me. _________________ The search for better is endless.  Instead simply find very good and get the job done. |
				 Posted: Tue Jan 20, 2009 3:06 pm     |
				Vs. 4.066 generates a warning. You need to enable warnings.
 	  | Quote: | 	 		  | >>> Warning 207 "pcm_test.c" Line 12(1,1): Code has no effect |
MSVC 6.0 generates a similar warning if you try a similar program with it:
 	  | Quote: | 	 		  | warning C4552: '~' : operator has no effect; |
Test program:
 	  | Code: | 	 		  #include <16F877.h>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
int8 value;
~value;
