mshearer
| parity function |
Posted: Tue Jan 20, 2009 3:44 am |
Hi
I am using the following two functions to test the parity of a sent char.
| Code: | char check_parityRCREG(void)
char check_parity_result = FALSE;
received_byte = reg_RCREG;
if(bit_RX9D == parity_errorDetection(received_byte))
check_parity_result = TRUE;
received_byte = ZERO;
return check_parity_result;
| Code: | char parity_errorDetection(char cms_rc_message)
char rx_loop_count = ZERO;
char rx_bit_count = ZERO;
char parity_detect_result = FALSE;
for(rx_loop_count = ZERO; rx_loop_count < ONE_BYTE; rx_loop_count++)
if((cms_rc_message & ONE) == TRUE)
rx_bit_count++;
cms_rc_message >>= ONE;
if((rx_bit_count & ONE) == FALSE) // Check the parity
parity_detect_result = TRUE;
return parity_detect_result;
the code works well for a the majority of the time. Except on the very first inputted char, also with certain combinations, such as a 'T' following a 'Y'
Considering all the variables should be zeroed at each call, i can't figure out whats going wrong.
thanks, for any help
matt |
mshearer
Posted: Tue Jan 20, 2009 4:03 am |
and the some more needed to compile/test etc
| Code: | #include <18f4520.h>
#fuses H4,NOWDT,WDT128,NOPROTECT,NOBROWNOUT,NOPUT,STVREN,DEBUG,NOLVP,WRT,NOWRTB,NOWRTC,NOCPD,NOCPB,NOEBTR,NOEBTRB
#use delay(clock=40000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=O)
#define ZERO 0x00
#define ONE 0x01
#define TWO 0x02
#define ONE_BYTE 0x08
#byte reg_RCREG = 0xFAE
#byte reg_RCSTA = 0xFAB
#bit bit_RX9D = reg_RCSTA.0
#byte reg_PIR1 = 0xF9E
#bit bit_RCIF = reg_PIR1.5
char received_byte= 0;
char check_parityRCREG(void);
char parity_errorDetection(char cms_rc_message);
if(bit_RCIF == TRUE)
check_parityRCREG();
mshearer
Posted: Tue Jan 20, 2009 5:32 am |
turns out my terminal program isn't sending a reliable 'odd' parity
the first 'Y' will give parity bit '0'
from then on it will give '1'
bit of a pain |
