EdwardH
| PIC18F87J60 oscillator problem |
Posted: Tue Jan 13, 2009 9:34 am |
I'm trying to write a program for the PIC18F87J60 and I started with a simple LED flash, however when I run this on the chip the LED flashes with only a 5.28uS delay not 500ms. There's a 25MHz crystal attached.
Any ideas? I've tried manually setting the OSCTUNE register etc with no success.
Edward
| Code: | #include <18F87J60.h>
#device adc=8
#FUSES HS //High speed Osc
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#FUSES PRIMARY //Primary clock is system clock when scs=00
#FUSES ECCPE //Enhanced CCP PWM outpts multiplexed with RE6 thorugh RE3
#FUSES ETHLED //Ethernet LED enabled
#FUSES RESERVED //Used to set the reserved FUSE bits
#use delay(clock=25MHZ, oscillator=25MHZ)
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
output_high(PIN_B3);
while (1)
output_low(PIN_B2);
output_high(PIN_B2);
Posted: Tue Jan 13, 2009 9:49 am |
The CCS compiler does not support XINST. May not be the problem, but code is unlikely to work right with this fuse set.
EdwardH
Posted: Tue Jan 13, 2009 9:55 am |
Thanks, that's what it was!
I just used the project wizard to start with and it added the fuse by default. |
