compilation
praveenhegde
compilation
PostPosted: Mon Jan 12, 2009 7:51 am     Reply with quote
Is it possible to compile multiple files using CCS compiler?
I have a problem in executing multiple files with break points.
I can't put break points any where except main function.
Please tell me the cause and how to fix it.
dyeatman
PostPosted: Mon Jan 12, 2009 9:55 am     Reply with quote
What CCS version do you have?
The version number is in the format 3.xxx or 4.xxx
praveen hegde
compiler
PostPosted: Tue Jan 13, 2009 12:02 am     Reply with quote
The version is 4.14.10.14.
When there are more than one (.c ) files break point is not working properly and i cant place the break point inside other function except main function.
If i place all the code in a single file, break point is working.
Does this compiler support multiple file compilation??
If yes , how to do it?
Thanks in advance.
