shirish
| #Fuses |
Posted: Thu Jan 08, 2009 3:49 am |
I have used the #fuses to configure the contoller, but it has no effect on code.
i.e. I have used code protect & EEprom read protect but it has no effect.
#include "16F887.h"
#fuses INTRC_IO,WDT,PUT
#fuses MCLR,PROTECT,CPD,BROWNOUT
#fuses BROWNOUT_NOSL,NOLVP
#fuses DEBUG,WRT
#ZERO_RAM
#DEVICE ICD=TRUE |
Posted: Thu Jan 08, 2009 12:02 pm |
| Quote: | #include "16F887.h"
#fuses DEBUG,WRT
#ZERO_RAM
#DEVICE ICD=TRUE |
The line in bold will cause the compiler to disable your PROTECT
statement.
Here is the reason. From the MPLAB ICD2 Help File:
| Quote: |
Q: Can I use code protection with MPLAB ICD 2?
A: No. Code protection, especially table read protection on any area in
program memory will prevent MPLAB ICD 2 from functioning. Do not use
any code protection or table read protection configuration settings when
debugging with MPLAB ICD 2. Code protection can be enabled when
programming a part for testing without MPLAB ICD 2. |
