Problem with simple program !
Andrew83
PostPosted: Tue Jan 06, 2009 3:32 am     Reply with quote
Hello !
I have a problem with the following program that normaly should work flawlessly. I am trying to make a led blink for a period of 0,842 ms. Where is my mistake ?
I'm using CCS C compiler version 4.057, pic18f452 and a 10 MHz clock.
Here is the code :
#include <18F452.H>
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=10MHZ)
#INT_TIMER0
void timer0_isr( )
output_toggle(pin_B1);
set_timer0(0);
 setup_timer_0(RTCC_INTERNAL |RTCC_8_BIT | RTCC_DIV_16);
 set_timer0(129);
Thank you for your input !!!
PostPosted: Tue Jan 06, 2009 7:48 am     Reply with quote
Andrew,
What is the problem? Does the LED blink at the wrong rate or not blink at all?
Andrew83
PostPosted: Tue Jan 06, 2009 8:02 am     Reply with quote
Hello dyeatman!
The problem is that the led lights up as it should at 0,8146 ms (the closest interval to 0,842 ms that i could come up with), but turns off at about 2,4 ms. The total time that timer zero should run is 1,6 ms and i wanted that for 0,842 ms the led should be on and for the rest time the led should be off.
I am noticing that the led turn off at 0,842 + 1,6 ms.
I wonder why is this happening ?
Thank you four your time and patience !!
Andrew83
PostPosted: Tue Jan 06, 2009 8:05 am     Reply with quote
And another thing ...i've verified that the interrupt triggers every 1,6 ms....That part is ok ..I think that it's something to do with the way that i initialize my timer, aka set_timer0(129).
Is this the right way to initialize a timer to get a custom interrupt value ?
PostPosted: Tue Jan 06, 2009 8:19 am     Reply with quote
OK, let's look at what you have:
#INT_TIMER0
void timer0_isr( )
set_timer0(0);
 set_timer0(129);
If you think about the problem you will realize it's a little more complicated than what you have so far.
In Main you preset the clock to 129 then wait for the interrupt. After the interrupt fires you preset the Timer to 0. The timer runs the full timer length after that and never changes.
First you have to establish which part of the timer cycle you are in by defining a flag (i.e. LED_ON). Then, in the interrupt routine, you will have to alternate setting LED_ON true then false.
Example:
if LED_ON
set_timer0(xxx)
LED_ON = false
set_timer0(129)
LED_ON = true
Hopefully this will help get you on track. I will leave you to figure out the exact timer values needed.
Andrew83
PostPosted: Tue Jan 06, 2009 8:52 am     Reply with quote
Very Happy Hmmm ...i must have read your mind !
I am working on a similar solution right now ...hopefully it will solve my problem !
Thank you very much
