		| Author | Message |
		| Guest
				| Making hysteresis to A/D. |
				|  Posted: Fri Dec 19, 2008 9:11 am |   |
				| Using 8 bit A/D 0-255, want to use a pot. as a selector.
 I want 4 step and don't want toggling between the step, therefore I want to use some hysteresis maybe 5-10 count.
 Step without hysteresis.
 0-63  step 1
 64-127 step2
 128-191 step3
 192-255 step4
 How to make the smartest implementation?
		| libor
				|  Posted: Fri Dec 19, 2008 10:28 am |   |
				| I would just insert some 'neutral zones' between the 'steps'.
 0-59 valid step 1
 60 - 67  neutral zone
 68-123 valid step2
 124-128 neutral zone
 129-191 valid step3
 ...etc
 a reading in any neutral zone would result a no-change in the 'step'. (the previous state remains selected)  a simple sequence of   if()...  structures will do.
 However upon power-on you should initialize the step to the closest valid range.
		| Guest
				|  Posted: Fri Dec 19, 2008 11:01 am |   |
				| Like this...
  	  | Code: |  	  | void readad(){ const int8 hyst=5;
 int8 res;
 res=(int8)read_adc()&~0x03; //cutoff 2 bit
 if (res>0        && res<42+hyst){}  else
 if (res>42-hyst  && res<85+hyst){}  else
 if (res>85-hyst  && res<127+hyst){} else
		| RLScott
				|  Posted: Fri Dec 19, 2008 1:20 pm |   |
				|  	  | Anonymous wrote: |  	  | Like this...
 int8 res;
 No, I'm afraid this code will not implement hysteresis.  The first "if" guarantees that the second "if" will never see a value of res<47, so there is no point in looking for "res>42-5".  To implement hystersis, there must be some form of static memory of the previous range you were in, such as the variable "Range" in the following:
 const int8 hyst=5;
 int8 res;
 if (res<42-hyst)      Range = 0;
 else if(res<42+hyst)  Range = (Range<1) ? 0 : 1;
 else if(res<85-hyst)  Range = 1;
 else if(res<85+hyst)  Range = (Range<2) ? 1 : 2;
 else if(res<127-hyst) Range = 2;
 else if(res<127+hyst) Range = (Range<3) ? 2 : 3;
 switch(Range)
 case 0:  {} break;
 case 1:  {} break;
 case 2:  {} break;
 case 3:  {} break;
 Robert Scott
 Real-Time Specialties
 Embedded Systems Consulting
		| Guest
				|  Posted: Sat Dec 20, 2008 2:47 pm |   |
				| Nice code, thanks :-) |  |
