smash Guest
| help pwm !!!!! control step pwm |
Posted: Tue Dec 02, 2008 3:54 am |
I'm having problems using the PWM of my PIC16F877. I want to change pwm using delay time such as from set_pwm1_duty(100) to set_pwm1_duty(200), and change it in single steps using delay_ms(50) +1 delay_ms(50) +1 from 100 +1 delay 50ms -->101 +1 delay 50ms --->102 +1 delay 50ms ---->....... to 200 and 200----->100 pwm
Help me
#include <16F877.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
int c2,D2;
int16 value;
float c;
setup_timer_2(T2_DIV_BY_1,249,1); //20 khz
setup_ccp1(CCP_PWM);
setup_ccp2(CCP_PWM);
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_DIV_32);
while(true)
set_adc_channel(0);
delay_us(30);
value=read_adc(); //read adc
c = (float)(value * 5)/1023.0;
c2 = c*10; // max value 50
if(c2>=10)
output_high(PIN_B1);
output_low(PIN_B0);
D2=c2*2;// value = 100
set_pwm1_duty(D2);
else if(c2>=0)
output_low(PIN_B0);
D2=c2*4; // value = 200
set_pwm1_duty(D2);
Wayne_
Posted: Tue Dec 02, 2008 4:20 am |
If you want to continue monitoring the input while altering the PWM then something like this may do.
int speed = 100;
while(true)
set_adc_channel(0);
delay_us(30);
value=read_adc();//read adc
c2= c*10;// max value 50
if(c2>=10)
else if(c2>=0)
D2=c2*4;// value = 200
output_low(PIN_B0);
if (speed < D2)
speed++;
else if (speed > D2)
speed--;
set_pwm1_duty(speed);
delay_ms(50); // this will slow your response input response time down, there are other options if this is a problem!
