nicotec
| Hardware UART with bit stop 1.5 |
Posted: Mon Nov 24, 2008 12:34 pm |
Hi , as in subject I need to use UART serial module of PIC24FJ16GA002 with bit stop 1.5, but noted that is possible to set 1 (as default) or 2.
Since I need to connect a camera using RS232 with stop bit 1.5, I ask if it is possible.
Thank in advance.
Regards |
Posted: Mon Nov 24, 2008 1:36 pm |
| It sounds somewhat unlikely, but may be, 1.5 stop bits is actually used. Microchip processors don't directly provide this setting, you have to use workarounds. On reception, you need to set 1 stop bit not to cause errors. You may either switch to 2 stop bits on send (assuming a half duplex protocol) or send individual characters with a delay. |
Posted: Mon Nov 24, 2008 2:56 pm |
Yes. A UART set to 1 stop bit, will receive characters with 1.5 stop bits fine, while one set to 2 stop bits will send data that a UART set to use 1.5 stop bits will use fine. Remember that stop bit values are _minima_, so a receiver must always accept data with more stop bits (just a gap between the characters).
nicotec
| Solution |
Posted: Tue Nov 25, 2008 1:11 am |
Ok, thank You, so to send data to equipment with specification stop bit =1.5 I can use 2 stop bit, since I need only to send command to a camera.
I'll try and post here my result.
Bye |
