Program not downloaded in J-series micro
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
GunasekaR
PostPosted: Wed Nov 12, 2008 6:38 am     Reply with quote
I'm using ICD-U40 and pic18F85J15.
Target test passed.
After downloading programmer popups some errors:
Actual ... and expected... values
So my code is not loading.
this is the code i'm using to check:
#include <18F85J15.h>
#fuses HS,NOWDT,NOXINST
#use delay(clock=12288000)
#define RED_LED   PIN_H2
      OUTPUT_HIGH(RED_LED);
      DELAY_MS(1000);
      OUTPUT_LOW(RED_LED);
      DELAY_MS(2000);
Can anyone help me for this issue......
ICD shows the device ID is not matching
the required ID is 1700 but the ic is showing 1703
i verified it many time but it showing the same value
anyone help for me .. this is serious issue for me ......
Embarassed Question Question
treitmey
PostPosted: Wed Nov 12, 2008 9:46 am     Reply with quote
In the ICD program has a checkbox in the lower left.
"J series PIC"
Did you check that box?
GunasekaR
PostPosted: Wed Nov 12, 2008 9:57 am     Reply with quote
Yes we did.
GunasekaR
PostPosted: Sat Nov 15, 2008 12:01 am     Reply with quote
I checked that microchip datasheet for device id.
1700 is the real ID.
1703 this caused because of Reserved bit.
I don't know why the ICD is checking the reserved bit.
Is anyone can help me plz do it as much as soon this is very important to me.
(This IC belongs to pic18f87j10 family)
rajshek_2010
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Tue Nov 18, 2008 8:52 am     Reply with quote
Now we are able to dump the code into micro controller by hard coding the 300000 and 300002 memory locations. But the program doesn’t seem to be working.
Following is the sample code written using CCS compiler J Series.
#byte CONFIG1L = 0X300000
#BIT  DEBUG = CONFIG1L.7
#BIT  XINST = CONFIG1L.6
#BIT  WDTEN = CONFIG1L.0
#byte CONFIG2L = 0X300002
#BIT  FOSC2 = CONFIG1L.2
#BIT  FOSC1 = CONFIG1L.1
#BIT  FOSC0 = CONFIG1L.0
#define RED_LED   PIN_H3
   WDTEN = 0;
   DEBUG = 1;
   XINST = 0;
   FOSC1 = 0;
   FOSC0 = 0;
   FOSC2 = 1;
      DELAY_MS(500);
      DELAY_MS(500);
As a next step, we removed
from the code. The program started working but couldn’t use delay_ms routines.
Kindly advise.
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
