gnz
| 18F2620 SPI Slave Problem with SS pin |
Posted: Sat Nov 15, 2008 4:53 am |
Hi everybody,
I have a problem with the SPI communication.
18F2620 (Rev 0x6) is slave and my SPI is configured by setup_spi(SPI_SLAVE) command. I've watched the SDO,SDI,SS and SCK lines and they are correct. 18F2620 osilator is configured as 8MHz internal and clock is 32MHz with PLL.
(Fisrt SS pin from high to low. After 50 microsecond SCK gets from high to low 8 times (50microsecond each) and SCK gets high after 50 microsec SSpin gets high)
But SSP interrupt never occurs. But when i use setup_spi(SPI_SLAVE|spi_ss_disabled) , SSP interrupt occurs and i get the true data from the SPI. But for sycronizing i need to use SS pin RA5. Now i do it by software like
if (!input(PIN_A5))
setup_spi(spi_slave | spi_ss_disabled);
while (!input(PIN_A5)) {}
setup_spi(FALSE);
Is there any problem with the SlaveSelect pin or need any confugiration for the 2620. Thanks for your help. |
Posted: Sat Nov 15, 2008 8:03 am |
One problem is that you haven't configured the SPI mode in your slave.
SPI hardware works in one of four modes, depending on the combination of two parameters:
1) initial clock level.
2) Sampling data on the first or second clock edge, regardless of whether that clock edge is rising or falling.
Because CCS uses a signal naming different from what either Motorola or Microchip has defined, I always use the following 'translation' definitions. | Code: | // Clock base Sample on
#define SPI_MODE_0 (SPI_L_TO_H | SPI_XMIT_L_TO_H) // low leading edge
#define SPI_MODE_1 (SPI_L_TO_H) // low trailing edge
#define SPI_MODE_2 (SPI_H_TO_L) // high leading edge
#define SPI_MODE_3 (SPI_H_TO_L | SPI_XMIT_L_TO_H) // high trailing edge
Usage example:
setup_spi(SPI_SLAVE | SPI_MODE_0); |
You have configured: | Code: | | setup_spi(SPI_SLAVE) | Checkout the header file for your processor and you will find out this equals to: | Code: | | setup_spi(SPI_SLAVE | SPI_L_TO_H) | This is SPI mode 1 which expects the clock level to be low in inactive state, from your description we understand the clock level is high in inactive state and thus is a mismatch.
Find out the SPI mode of your SPI master and setup the slave to use the same mode. With the initial clock level high this will be either mode 2 or 3.
More information on SPI: http://en.wikipedia.org/wiki/Serial_Peripheral_Interface_Bus |
gnz
Posted: Tue Nov 18, 2008 4:14 am |
Hi ckielstra,
I have added the setup_spi(SPI_SLAVE | SPI_MODE_1); to my code but nothing changes the problem is with the spi_ss_disabled. When i use this, it is ok i can communicate over SPI, but when i did not use it, SPI port doesnt take any clocks. Here is my code
#include "18F2620.h"
#device ICD=TRUE
#device adc=8
#FUSES PROTECT //Code protected from reads
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES PUT //Power Up Timer
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES MCLR
#use delay(internal=8M, clock=32M)
int1 ADCConverted;
int8 ADCResult;
// TIMER0 INTERRUPT //
#int_TIMER0
void TIMER0_isr(void)
static int8 DigitCounter = 0;
DigitCounter++;
// TIMER1 INTERRUPT // adc'i çalıştırır.
#int_Timer1
void TIMER1_isr(void)
if (ADCConverted)
read_adc(ADC_START_ONLY);
ADCConverted = FALSE;
// ADC INTERRUPT ROUTINE // adc nin sonucunu alır.
#int_AD
void AD_isr(void)
ADCResult = read_adc(ADC_READ_ONLY);
ADCConverted = TRUE;
int16 DataIn;
setup_oscillator(OSC_32MHZ); // sets up the osilator to work in PLL mode 8Mhz * 4 = 32 MHz
setup_adc_ports(AN0|VREF_VREF);
setup_adc(ADC_CLOCK_DIV_64|ADC_TAD_MUL_20);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32|RTCC_8_bit); // Timer0 interrupt period = 1.0msec
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8); // Timer1 interrupt period = 65.5 msec
set_adc_channel(0);
delay_us(10);
enable_interrupts(INT_AD);
disable_interrupts(INT_SSP);
if (spi_data_is_in())
DataIn = spi_read();
This code never breaks at the line DataIn = spi_read();
But when i use setup_spi(SPI_SLAVE|SPI_MODE_1|SPI_SS_DISABLED); it works. When slave select mode, if SS pin gets into low, the SDO gets from low to high automatically and it gets to low slowly when the SS pin gets into high.
C1 = Chip Select (pin7 (RA5) of 2620) C2 = SCK (pin14 (RC3) of 2620)
Posted: Tue Nov 18, 2008 1:27 pm |
| Quote: | #FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES LPT1OSC |
I didn't even look at the rest of your code. These two fuses are a major
problem. With LVP set, if pin B5 goes high, the PIC will go into low
voltage programming mode. It will appear to mysteriously "lock up".
Change that fuse to NOLVP.
With the XINST fuse, the PIC expects to get machine code that works
with the "extended instruction set". But the CCS compiler doesn't
support that. With XINST, your program will act in an erratic manner.
It will appear to be extremely buggy. Change it to NOXINST.
Do these two things in all future programs. |
gnz
Posted: Wed Nov 19, 2008 2:12 am |
| Thanks for your warn, PCMprogrammer. I've changed these two configuration, and I still have problem with the SS. |
gnz
Posted: Wed Nov 19, 2008 2:36 am |
Problem is solved. Thanks for everybody for the replies.
The problem is solved by adding a 100ohm resistor between the 18f2620 SSpin and the chip select output of the master microcontroller.
I've found the solution from this post; http://www.ccsinfo.com/forum/viewtopic.php?t=21650&start=8
| Quote: |
Okay, we figured out the problem. It turns out the solution was buried in the Errata document of the 18f252:
10. Module: MSSP (SPI, Slave Mode)
In its current implementation, the SS (Slave
Select) control signal, generated by an external
master processor, may not be successfully recognized
by the PIC� microcontroller operating in
Slave Select mode (SSPM3:SSPM0 = 0100). In
particular, it has been observed that faster
transitions (those with shorter fall times) are more
likely to be missed than than slower transitions.
Work around
Insert a series resistor between the source of the
SS signal and the corresponding SS input line of
the microcontroller. The value of the resistor is
dependent on both the application system�s
characteristics and process variations between
microcontrollers. Experimentation and thorough
testing is encouraged.
This is a recommended solution. Others may exist.
We used a 100 ohm resistor in series with the SCK line. It worked right off the bat...
18F252 errata helps but i couldn't find a solution like this at the errata of 18F2620. I think i could not read carefully. |
