FT232 and handshaking.
davidbue
PostPosted: Thu Nov 13, 2008 1:58 pm     Reply with quote
Hi everybody!
I've just migrated from using the MAX232/ST232 for serial communication to the FT232R chip from FTDI.
So far I haven't had any problems using the FTDI chip, but one thing puzzles me.
When I used the MAX232 serial interface I always used:
Bitrate:9600
Data bits:8
Parity:none
Stop bits:1
Flow control:None
Now, when I use the FT232R chip I have to use this instead:
Bitrate:9600
Data bits:8
Parity:none
Stop bits:1
Flow control:Xon/Xoff
Sooo.... what I don't understand is why I now have to use flow control. The code I use in the CCS compiler is the same as with the Max232 interface. Is it something I have to set up on the FT232R chip using the programmer supplied by FTDI?
Hope that one of you can explain it to me.
Thank you, thank you!
David
PostPosted: Thu Nov 13, 2008 2:03 pm     Reply with quote
Look at section 4.3 of this FTDI appnote:
http://www.ftdichip.com/Documents/AppNotes/AN232B-04_DataLatencyFlow.pdf
davidbue
PostPosted: Thu Nov 13, 2008 2:52 pm     Reply with quote
Hi PCM programmer.
As always you have the answer. You're a great guy to have hanging around on the forum.
Thank you.
