SD Card oddities |
Posted: Mon Nov 10, 2008 5:07 pm |
I'm using PCD 4.079 and a dsPIC30F4011. I'm using sparkfun's MMC/SD breakout board, and voltage dividers on the SDO, SCK, CS, and VDD lines. Using ex_mmcsd.c, I've been able to successfully write and read data. But it seems like the first byte either isn't written or isn't read. If I do this:
address = 0x00001234;
for(x=0;x<5;x++)
mmcsd_write_byte(address,x);
mmcsd_read_byte(address++,&val);
printf("value = %u, ",val);
The output is "value = 104, 1, 2, 3, 4,"
but if I put a dummy write in front of the for loop, everything works fine.
Then, If I separate the writing and reading into separate files, and still write 1,2,3,4,5 to consecutive addresses, I get back 1,4,6,8,10.
Does this make sense to anyone? |
Posted: Mon Nov 10, 2008 8:03 pm |
Edit: In the two program scenario, the sequence stored is 0,1,2,3,4, not 1,2,3,4,5. |
asmallri
Joined: 12 Aug 2004 Posts: 1642 Location: Perth, Australia
Re: SD Card oddities |
Posted: Mon Nov 10, 2008 8:10 pm |
Anonymous wrote: | I'm using PCD 4.079 and a dsPIC30F4011. I'm using sparkfun's MMC/SD breakout board, and voltage dividers on the SDO, SCK, CS, and VDD lines. |
I assume you mean SDO out from the PIC - SDI in to the card.
What do you mean by voltage divider on VDD?
If you mean by this that you are attempting to generate 3.3volts from 5 volts for the card using a voltage divider then this will not work. The cards consume a very low average current but consume a high current during a write operation - up to 200mA worst case for a standard SD card.
If you do not want to use a LDO regulator to derive the 3.3volts then you could use 2 x 1N4148 diodes in series between the +5v rail and the +3.3 volt rail of the card. If you do this then add a 100K resistor from the cards 3.3volt rail to ground. In addition you should add a 10uF ESR (such as tantalum) capacitor and a 0.1uF monolithic capacitor between the power and ground terminals of the socket.
Do you also have a pullup resistor on SDO out of the card (SPI IN to the PIC)? _________________ Regards, Andrew
Posted: Mon Nov 10, 2008 8:51 pm |
I know the signals are going to the right pins. It wouldn't work even intermittently if they weren't.
Yes, I am creating ~3.3V from 5V with a 3k and a 1.6k. I do know that my wall wart powering my devboard, and therefore the sd card, is limited to 200mA. I guess I assumed that it couldn't work intermittently. I have no problem using a regulator, I was really just doing a proof of principle, and keeping it simple.
I will try a 3.3V regulator, a beefier power supply and a 10k pullup resistor. |
asmallri
Posted: Mon Nov 10, 2008 9:19 pm |
In this case I am surprised you got it to work as well as you did. _________________ Regards, Andrew
Posted: Tue Nov 11, 2008 2:35 pm |
I've put an adjustable regulator, set to 3.3V and a 15k pullup to 5V on the Data out pin from the SD card. I still get the same error, a bad first byte read back.
I've also noticed that I have to run the code twice to get output. The first time it runs, it hangs. But on a reset, it works. Another reset makes it hang again, and yet another makes it work again. So I kept advancing an output_high(PIN_B1) statement (turns on an LED) to see how far the code makes it, and where it hangs.
What I found was that on the times is doesn't work, the if (g_MMCSDBufferChanged) statement in mmcsd_flush_buffer() evaluates to true, while on the times it does work, the if statement fails.
So, when the buffer has changed, the buffer is flushed, and mmscd_write_block() is called. Inside this function, towards the end, there is a while() statement that writes 0xFF to the SPI bus and won't exit until a 0 is returned. My problem stems from the 0 never being returned, and the while loop becomes infinite.
Once I commented out the while() statement, it works every time. This does not correct the need for the extra dummy write at the beginning though.
So I have two workarounds to make it work, not waiting for the SPI line to return to low, and writing a dummy byte. But I would still like to get to work without the workarounds.
Any ideas? |
asmallri
Posted: Tue Nov 11, 2008 3:50 pm |
Anonymous wrote: | I've put an adjustable regulator, set to 3.3V and a 15k pullup to 5V on the Data out pin from the SD card. |
Is the regulator an LDO device? You needs one that will work with a minimal voltage drop from input to output (<1.25 volts).
The pullup should be to 3.3 volts this is because the SD card is only open drain during initialization and totem pole output otherwise.
Quote: |
I've also noticed that I have to run the code twice to get output. The first time it runs, it hangs. But on a reset, it works. Another reset makes it hang again, and yet another makes it work again. |
Are you sure about the final step? Without the final step it indicates a problem in the initialization stage. The final step indicates otherwise.
I can not comment on the the driver calls you are making because I use my own drivers however, ignoring the final step it looks like an SPI bus initialization problem - I suspect when the bus speed is being changed. _________________ Regards, Andrew
