		| Author | Message |
		| mpardinho
				| rs232 and getc |
				|  Posted: Wed Nov 05, 2008 4:57 am |   |
				| i can't work  'if"
 if ((letra[5] == 'O') && (letra[4] == 'F')){
  	  | Code: |  	  | #include <18F252.h>
 #FUSES HS
 #FUSES WDT
 #FUSES WDT128
 #FUSES NOLVP
 #FUSES CPB
 #FUSES PROTECT
 #use delay(clock = 8000000)
 #use rs232(baud = 9600, parity = N, xmit = PIN_C6, rcv = PIN_C7, bits = 8)
 #define Led PIN_A0
 char letra[7];
 set_tris_a( 0b00000000 );
 set_tris_b( 0b01111111 );
 setup_adc_ports(NO_ANALOGS);
 setup_adc(ADC_OFF);
 setup_wdt(WDT_OFF);
 setup_timer_0(RTCC_INTERNAL);
 setup_timer_1(T1_DISABLED);
 setup_timer_2(T2_DISABLED, 0, 1);
 output_high( Led );
 delay_ms( 1000 );
 printf ( "\n\r\START\n\r" );
 output_low( Led );
 while (true) {
 letra[6] = getc();
 for (i = 1; i < 6; ++i) letra[i] = letra[i + 1];
 if ((letra[5] == 'O') && (letra[4] == 'N') ) && (letra[3] == 'N') ) {
 printf("ON");
 if ((letra[5] == 'O') && (letra[4] == 'F') ) && (letra[3] == 'F') ) {
 printf("OFF");
		| Ttelmah Guest
				|  Posted: Wed Nov 05, 2008 5:32 am |   |
				| Of course it won't.... You are writing each character to the location 'letra[6]'. Getc, gets _one_ character.
		| mpardinho
				|  Posted: Wed Nov 05, 2008 5:37 am |   |
				| i put caracter 2 in 1, 3 in 2 for (i = 1; i < 6; ++i) letra[i] = letra[i + 1];
 i get 1 caracter in 6 and put i 5
 if i test in proteus is 100% code works
		| tinley
				|  Posted: Wed Nov 05, 2008 5:40 am |   |
				| if ((letra[5] == 'O') && (letra[4] == 'N') ) && (letra[3] == 'N') ) { printf("ON);
 printf("OFF);
 two many brackets in wrong places! Change to this:
 if (letra[5] == 'O' && letra[4] == 'N' && letra[3] == 'N' ) {
 printf("ON);
 if (letra[5] == 'O' && letra[4] == 'F' && letra[3] == 'F' ) {
 printf("OFF);
		| tinley
				|  Posted: Wed Nov 05, 2008 5:43 am |   |
				| Oh, and the printf's are wrong too. Missing quotes, change:
 printf("OFF);
 to this:
 printf("OFF");
 and the same with ON
		| mpardinho
				|  Posted: Wed Nov 05, 2008 6:03 am |   |
				| i change code......i post without " the problem is in if(
 if(letra=='o' ...........
 IN PROTEUS WORK
		| Wayne_
				|  Posted: Wed Nov 05, 2008 6:05 am |   |
				| You must be sending "NO" and "FFO" ?
 if you send "ON"
 "O" ->
 letra[6] = "O"
 "N"->
 letra[5] = letra[6] ('O')
 letra[6] = "N"
 so your check would be if ((letra[5] == 'O') && (letra[6] == 'N'))
 You have extra ; at the end of your if braces aswell. Won't hurt but don't need them!
 if (...)
 }  // <-- No ; required
