for(x = 0 ; x < 8 ; x++)
SDI = outgoing_byte.7; //Put bit on SPI data bus
outgoing_byte <<= 1; //Rotate byte 1 to the left
SCL = 0; //Toggle the SPI clock
SCL = 1;
incoming_byte <<= 1; //Rotate byte 1 to the left
incoming_byte.0 = SDO; //Read bit on SPI data bus
I try to transfer it to be used on PIC18F452 with CCS,
but there are some problems such as the outgoing_byte.7.
It should be take as the highest bit of outgoing_byte
but I never see that before.
I don't know if that program can be accepted by CCS.
Otherwise how I can change that into my own ?
Thx for all your answer.
Monk666
SPI c code problem
Posted: Sat Oct 25, 2008 10:12 am
Here is the original code for Triple Axis Accelerometer.
I am trying to transfer this code to be use in my PIC18F452 with CCS.
asmallri
Joined: 12 Aug 2004 Posts: 1658 Location: Perth, Australia
Posted: Sat Oct 25, 2008 10:24 am
If you are interested I sell a $20 driver for this sensor written in Microchip C30 for the PIC24 family using hardware SPI. It would be straight forward to port to CCS and I can assist you to do it.
In the my application the driver was used to scan X, Y & Z every 2ms (500Hz). The driver is capable of a higher sampling rate but I was also using a Magnetometer that was not capable of sampling faster. _________________ Regards, Andrew
