WORKING WITH ICD2 (USB) IN CCS C
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
thedemri
PostPosted: Sat Sep 22, 2007 3:41 pm     Reply with quote
Hi
Is it possible to work with ICD2 (usb connection) from within the CCS compiler ?
Thanks Amnon
ratgod
PostPosted: Mon Oct 01, 2007 4:58 pm     Reply with quote
unfortunately not.
I asked microchip if they had a separate utility for programming using
the ICD2 so I could configure it for CCS but they said that MPLAB is the
only software that uses the ICD2.
I got really tired of MPLAB crashing every 5 minutes and got myself one
the the CCS ICD units, its great, it doesn't update when changing PIC
families as much as the ICD2 and seems to be a little faster.
the only downside is that if you want the ICD to supply 5v you need to
put in the jumper inside the device and does not have a power in socket
like the ICD2.
Ajison
Re: WORKING WITH ICD2 (USB) IN CCS C
PostPosted: Mon Dec 17, 2007 11:59 am     Reply with quote
thedemri wrote:
Hi
Thanks Amnon
PostPosted: Mon Dec 17, 2007 12:09 pm     Reply with quote
Read this news item on the CCS website:
CCS IDE Supports Microchip ICD2 and REAL ICE™
Thursday 29 November, 2007
Here is the link:
http://www.ccsinfo.com/newsdesk_info.php?newsPath=ALL&newsdesk_id=86
You must have compiler vs. 4.064 or higher, and you must have
MPLAB 8.0 or higher.
Here is the FAQ link:
http://www.ccsinfo.com/faq.php?page=icd2_real_ice
Lars Olsson
PostPosted: Fri Mar 21, 2008 8:12 am     Reply with quote
I did all the instructions but still don't get any ICD2 option on the PWCH-menu. The extracted interface module was automatically placed in c:/program/picc/dll. Is that OK?
Do I have to activate the module in some way?
Lars Olsson
Sweden
daniele.baroncini
PostPosted: Tue Apr 01, 2008 7:22 am     Reply with quote
Lars Olsson
Sweden
I'm tring to work with ICD2 too, but even i can't get the ICD2 option in the PWCH-menu, only the CCS ICD options.
Simnix
PostPosted: Fri Oct 24, 2008 10:08 am     Reply with quote
The ICD2 will only work when debugging in CCS's IDE. It has not been implemented for programming yet, CCS is going to implementing this feature in a future version. Rolling Eyes
If you want to debug using the ICD2 download the MPLAB® ICD2 & MPLAB® REAL ICE™ Interface from CCS Download page
I am currently working on editing the user defined tools section to call the ICD2 dll file in MPLAB, I will post when I have a working version.
Simnix
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
