| Interrupt handling? |
Posted: Fri Oct 24, 2008 8:36 am |
Hi
In my code I disabled ext_x interrupt but poll for it.
My Q is what way does the pic / ccs handle this ?
The pic will goto addr: 0008 and execute the ccs dispatcher code but the ccs code is real long.
| Code: | 0008: MOVWF 05
000A: MOVFF STATUS,06
000E: MOVFF BSR,07
0012: MOVLB 0
0014: MOVFF FSR0L,0D
0018: MOVFF FSR0H,08
001C: MOVFF FSR1L,09
0020: MOVFF FSR1H,0A
0024: MOVFF FSR2L,0B
0028: MOVFF FSR2H,0C
002C: MOVFF PRODL,14
0030: MOVFF PRODH,15
0034: MOVFF PCLATH,16
0038: MOVFF 00,0F
003C: MOVFF 01,10
0040: MOVFF 02,11
0044: MOVFF 03,12
0048: MOVFF 04,13
004C: BTFSS INTCON.INT0IE
004E: GOTO 0058
0052: BTFSC INTCON.INT0IF
0054: GOTO 00AA
0058: BTFSS INTCON3.INT1IE
005A: GOTO 0064
005E: BTFSC INTCON3.INT1IF
0060: GOTO 00B2
0064: MOVFF 0F,00
0068: MOVFF 10,01
006C: MOVFF 11,02
0070: MOVFF 12,03
0074: MOVFF 13,04
0078: BSF 0E.7
007A: MOVFF 0D,FSR0L
007E: MOVFF 08,FSR0H
0082: MOVFF 09,FSR1L
0086: MOVFF 0A,FSR1H
008A: MOVFF 0B,FSR2L
008E: MOVFF 0C,FSR2H
0092: MOVFF 14,PRODL
0096: MOVFF 15,PRODH
009A: MOVFF 16,PCLATH
009E: MOVF 05,W
00A0: MOVFF 07,BSR
00A4: MOVFF 06,STATUS
00A8: RETFIE 0 |
.................... #INT_EXT
.................... void ext0(void){int a; a=0;}
00AA: CLRF a
00AC: BCF INTCON.INT0IF
00AE: GOTO 0064 |
I ask because I wrote some code that must be real fast and therefore must poll in a loop for the EXTxIF, but will the pic will go to addr 0008 and execute the code???
Some hints. |
Posted: Fri Oct 24, 2008 9:07 am |
Nothing to do with the compiler...
This is down to how the _chip_ handles interrupts.
The code really doesn't 'come into it'.
There are three flag bits associated with each interrupt:
First, the 'flag'. This is set by the hardware event. The event on some interrupts may be changed (so on the level interrupts for example, you may change whether this is set by a rising or falling edge).
Then the individual 'enable'. This is controlled by the enable/disable interrupt call.
Then the 'global' enable (set by the same calls, but using #INT_GLOBAL).
The interrupt handler (at address 8), is _only_ called, when all three bits are set.
You have turned off the 'enable', so the handler will not be called.
Clearing the interrupt will become your responsibility (the compiler will automatically clear interrupts when the 'handler' routine is called).
Also remember that for some interrupts (serial data received, RB change etc.), the event causing the interrupt itself, _must_ be cleared before the interrupt can be cleared.
For the '18' chips, there is also another bit involved, the hardware 'priority' flag. This has it's own caveats.
Remember, that though testing the flag bit is a great idea to remove the latency implicit in calling the handler, if you have other interrupt sources enabled, and a chage occurs while the code is in the handler for these, you will not return to the 'main' routine, till this handler has completed, potentially 're-introducing' latency problems.
Posted: Sat Oct 25, 2008 2:38 am |
Hi
Sorry for the late response.
In this ex will addr 0008 NOT be entered because the INT0IE=0. ?
| Code: | INT0IE=0;//dis int
INT0IF=0;//clear pending int
while (!INT0IF);//wait for int
...more code... |
