Andreas
| Max Frequency on a 18F2420 @ 4MHz ?? |
Posted: Mon Oct 20, 2008 3:11 am |
Hi Friends,
I am using a 18F2420 with a 4MHz Crystal, can somebody tell me what the maximum frequency on a timer1 overflow can be ?
I use the following test programm where I get max 23,26kHz output Frequency
Can somebody point me to my error ??
best regards
ANdreas
#include <18F2420.h>
#device adc=8
#FUSES H4 //High speed osc with HW enabled 4X PLL
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#use delay(clock=16000000)
#int_TIMER1
void TIMER1_isr(void)
set_timer1(0xFFFF);
output_toggle(PIN_A3);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_OFF);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
setup_vref(FALSE);
RLScott
| Re: Max Frequency on a 18F2420 @ 4MHz ?? |
Posted: Mon Oct 20, 2008 6:59 am |
The timer interrupt frequency in your code is determined by the time it takes for the CCS interrupt dispatcher to determine which interrupt source caused the interrupt plus the time it takes your TIMER1_isr to toggle the output pin. If you want to speed that up, and if you know that TIMER 1 is going to be the only interrupt enabled, then you can skip the CCS interrupt dispatcher code and write your own global interrupt handler. I should point out that Timer 1 really has no purpose in this code. In your interrupt code you load Timer 1 with 0xffff, so it is going to overflow on the very next instruction. So the interrupt flag will be set before you ever get back to the main program. Your main program does not get any time at all. You might as well write a busy-loop in main, like:
It will do the same thing as your code, but much faster. _________________ Robert Scott
Real-Time Specialties
Embedded Systems Consulting |
Andreas
Posted: Mon Oct 20, 2008 7:05 am |
Hi Scott,
The reason for this code, was to test what frequency i can generate with the timer interrupt.
My project is to make a replacement for IR Remotes with different Carrierfrequencies.
I want to send e.g. 32kHz bursts, so in Your opinion whats a good way to to it ?
Also I need to measure the burst frequency in an range of 24kHz up to 44kHz.
Any Idea ?
and bestregards
Andreas |
RLScott
Posted: Mon Oct 20, 2008 7:34 am |
| Andreas wrote: | Hi Scott,
...I want to send e.g. 32kHz bursts, so in Your opinion whats a good way to to it ?
I would use Timer 2 and PWM. Set the duty cycle to 50% to turn on the 32kHz signal, and then set it to 0% to turn it off. To get 32kHz, you need a Timer 2 period of 31 uSec. Then set CCPR1L = 15 to turn on the signal and set it to 0 to turn off the signal.
| Quote: |
Do you mean you need to measure what that frequency is in kHz? Or do you only have to detect the presence or absence of this signal to decode IR transmissions? _________________ Robert Scott
Andreas
Posted: Mon Oct 20, 2008 2:49 pm |
Hi Robert,
Thanks for your explanations, I will try it now with Timer2.
Yes I need to measure the frequency in KHz of the incoming signal.
best regards
Andreas |
RLScott
Posted: Mon Oct 20, 2008 5:44 pm |
| Andreas wrote: | Hi Robert,
Andreas |
How accurately and how often? _________________ Robert Scott
Andreas
Posted: Mon Oct 20, 2008 11:41 pm |
Hi Robert,
I need the measurement to determine which output Frequency a certain IR Remote Control has, so I think it has quite a tolerance.
Actually I need to measure it only once:
Function:
1. Press the learning button on the Remote transmitter
2. Get the IR Remote Control near to the fototransistor and measure the Burst frequency
3. Release the learning button
4. Out of this result, set the output Burst frequency
Thats it
I took already your considerations into my design. I have to free now the PWM Output Pins and will try it again. Thanks for Your help.
best regards
Andreas |
