| View previous topic :: View next topic   |
			embedded_tom
  Joined: 09 Oct 2008 Posts: 4 Location: Long Island, NY
				| Accessing hi byte of int16 in assembly |
				 Posted: Mon Oct 20, 2008 8:36 am     |
				I read through the forum and found a way to do this by using the '&' prefix: http://www.ccsinfo.com/forum/viewtopic.php?t=7220
 	  | Code: | 	 		     bcf     TMR1ON
   movf    Next_Time, W
   addwf   TMR1, F
   btfsc   C
   incf    TMR1H, F
   movf    &Next_Time+1, W
Next_Time is located at 0x28 according to the .lst file:
But it doesn't access 0x29 in the second movf!?!
 	  | Code: | 	 		                  00484 ....................    bcf     TMR1ON
0015 1010       00485 BCF    10.0
                00486 ....................    movf    Next_Time, W
0016 0828       00487 MOVF   28,W
                00488 ....................    addwf   TMR1, F
0017 078E       00489 ADDWF  0E,F
                00490 ....................    btfsc   C
0018 1803       00491 BTFSC  03.0
                00492 ....................    incf    TMR1H, F
0019 0A8F       00493 INCF   0F,F
                00494 ....................    movf    &Next_Time+1, W
001A 082A       00495 MOVF   2A,W
Adding parenthesis or dropping the "+1" doesn't work. Next_Time is declared as an int16.
My compiler is Ver 4.080. uP is rfPIC12F675 (12F675 w/RF transmitter).
Ideas?
Thanks.
Tom |
			RLScott
				| Re: Accessing hi byte of int16 in assembly |
				 Posted: Mon Oct 20, 2008 8:59 am     |
				Try this:
#byte Next_Time_H=Next_Time+1
   movf  Next_Time_H,W
This has the advantage of also working outside of the assembly language block as in:
   int  k;
  k = Next_Time_H;
  _________________ Robert Scott
Real-Time Specialties
Embedded Systems Consulting |
			embedded_tom
				 Posted: Tue Oct 21, 2008 7:26 am     |
				Thanks, but got this error for the #byte statement: Error 43  Expecting a declaration.
tom |
			RLScott
				 Posted: Tue Oct 21, 2008 7:30 am     |
				 	  | embedded_tom wrote: | 	 		  Thanks, but got this error for the #byte statement: Error 43  Expecting a declaration.
tom |
Please post the code showing how you used the #byte directive.  It is a valid CCS directive.  Look it up in the CCS help file. _________________ Robert Scott
			embedded_tom
				 Posted: Tue Oct 21, 2008 7:34 am     |
				I did review #byte in the CCS manual. Here's what I used:
 	  | Code: | 	 		  | #byte Next_TimeH = Next_Time + 1; |
Is #byte similar to "assign" in other compilers?
I just tried this & it worked:
 	  | Code: | 	 		  |    movf    make8(Next_Time,1), W |
Thanks for the push in the right direction!
tom |
			RLScott
				 Posted: Tue Oct 21, 2008 9:20 am     |
				 	  | embedded_tom wrote: | 	 		  I did review #byte in the CCS manual. Here's what I used:
The problem is the ';' at the end.  Take it off and it should work. _________________ Robert Scott
			embedded_tom
				 Posted: Tue Oct 21, 2008 2:30 pm     |
				Yep, that did it.
Thanks.
tom |
