ntgcp_08
| CCS Bootloader using Software Uart |
Posted: Tue Sep 23, 2008 7:05 pm |
I've searched for hours trying to find the answer... is it possible to use CCS's loader.c with a software UART?
I've used ex_bootloader.c, bootloader.h, and loader.c with a hardware uart and it works great. If I add FORCE_SW to the #use RS232 statement it doesn't work. Why?
I found the following topic but I have not been able to try it. Why would taking out the XON and XOFF make it work?
http://www.ccsinfo.com/forum/viewtopic.php?t=27980&highlight=software+uart+bootloader
I'm using 18F6722 but I've already used the two hardware Uarts, so I have to run my bootloader with a software Uart. I'm running the PIC at 4Mhz. I've tried setting up the software Uart at 19200, 9600, 4800, and 2400 and none of the baud rates work.
Is there a way to modify loader.c to work with a software Uart? |
