i would like a PIC16F877 + MAX485 circuit
atomy_kwang
PostPosted: Fri Sep 12, 2008 5:15 am     Reply with quote
Hello everyone
i would like a PIC16F877 + MAX485 circuit . who have this circuit
Please give to me
thank you very much
PostPosted: Fri Sep 12, 2008 6:47 am     Reply with quote
This is a SOFTWARE forum not a hardware forum. That being said, you need to learn how to use search on this board and Google to find the info you need. It took me 30 seconds to find over a dozen links on the subject both here and using Google.
Here is one:
http://www.ccsinfo.com/forum/viewtopic.php?t=25720
atomy_kwang
PostPosted: Fri Sep 12, 2008 10:29 pm     Reply with quote
Sorry , i dont know that i cant talk about hardware.
PostPosted: Sat Sep 13, 2008 10:01 am     Reply with quote
Hardware design is somewhat outside the focus of this forum. We generally talk about hardware in the context of debugging software issues (since this is the CCS C compiler forum) rather than circuit design. For PIC related circuit design the Microchip forum is a good resource.
However, you missed the point of my reply which was that a little searching would likely have provided the info you needed to a much greater extent than typically available from a simpe inquiry and faster than waiting on a reply...
I recommend you take a look at Sparkfun electronics. he has a LOT of interesting projects! Also try the following RS485.com links.
http://www.rs485.com/rs485spec.html
http://www.lammertbies.nl/comm/info/RS-485.html
Good Luck!
