/dev/human
Joined: 01 Sep 2008 Posts: 19 Location: Earth / Europe / Germany
| PWRTEN Fuse missing? |
Posted: Fri Sep 12, 2008 1:17 am |
Propably another stupid newbie question.
Using a PIC18F4523 I can't find the fuse for the power up timer delay. Where is my blind spot or what may be a workaround?
Off topic: Is my understanding correct that I may use write_configuration_memory () to reconfigure the PIC during operation. I could use it to reconfigure MCLR to digital input port.
/dev/human |
/dev/human
| Different Nomenclature PWRTEN = PUT |
Posted: Fri Sep 12, 2008 1:35 am |
Thanks a lot PCM Programmer,
I highly appreciate the high responsiveness of many forum users. My blind spot was not recognizing that Microchip uses "PWRTEN" and CCS "PUT".
However, dear CCS developers it would be helpful to use the same wording when talking about the same thing. |
Posted: Fri Sep 12, 2008 3:00 am |
The problem is that MicroChip, keep changing their minds....
The wake up delay fuse, on older chips, was called 'PUT', for 'power up timer', and CCS used this. Only on a couple of the latter chips, have MicroChip 'renamed' them, and used PWRTEN. Blame MicroChip...
/dev/human
Posted: Fri Sep 12, 2008 3:02 am |
| Okay: Dear Microchip developers: could you please stay consistant! |
