		| Author | Message |
		| help me Guest
				| ULN2803 with the pic 16f877 |
				|  Posted: Tue Sep 09, 2008 1:05 am |   |
				| hello i need some help. I am still writing on the source code to conect the stepper motor and ULN2803 with the pic 16f877.
 I try to show a motor rotate forward , backward , left , right and stop with five swicth
 The following is my code. Could you tell me where is the problem?
 this code
  	  | Code: |  	  | #define _PIC16F877_ // Use PIC16F877 device
 #ifdef _PIC16F877_
 #if defined(__PCM__)
 #include <16F877.h>
 #define TxD PIN_C6 // Define Transmitted Data
 #define RxD PIN_C7 // Define Received Data
 #define CLOCK_SP 20000000 // Clock Speed(Hz)
 #include <input.c>
 #BYTE port_b = 6
 #define FOUR_PHASE TRUE
 #ifdef FOUR_PHASE
 BYTE const POSITIONS[4] = {0b0101,
 0b1001,
 0b1010,
 0b0110};
 #else
 BYTE const POSITIONS[8] = {0b0101,
 0b0001,
 0b1001,
 0b1000,
 0b1010,
 0b0010,
 0b0110,
 0b0100};
 void main ()
 trisb =$00
 trisa =$ff
 adcon1 = 7
 lamp       var portb
 sw1        var portc.0
 sw2        var portc.1
 sw3        var portc.2
 sw4        var portc.3
 sw5        var portc.4
 lamp=0
 if(!sw1) then
 gosub speed1
 pause 50
 endif
 if(!sw2) then
 gosub speed2
 pause 50
 endif
 pause 10
 wend
 end
 speed1:
 lamp =$08
 pause 200
 while(sw2)
 lamp = lamp >> 1
 if lamp = $00 then lamp = $08
 pause 200
 wend
 return
 speed2:
 lamp =$01
 pause 200
 while(sw1)
 lamp = lamp << 1
 if lamp = $10 then lamp = $01
 pause 200
 wend
 return
		| Guest
				|  Posted: Tue Sep 09, 2008 1:37 am |   |
				| You are using the wrong programming language. The CCS compiler expects C, not BASIC. |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
