Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Sample code of Interrupt based SPI Slave?
James101
PostPosted: Sun Apr 30, 2006 1:39 am     Reply with quote
Hi everyone,
I am trying to setup a communication link between the two PICs using SPI. So far, the slave receives data from the master correctly for about 70% of the time.
The Slave is using SS signal, with interrrupt on SSPIF.
Does anyone have a sample code of a WORKIING Interrupt based SPI Slave?
Thank you and best regards,
James
PostPosted: Mon May 01, 2006 12:54 am     Reply with quote
Does anyone have a sample code of a WORKING Interrupt based SPI Slave?
Here is a demo program. This program takes characters that
are typed in on the PC's keyboard and sends them out via
software SPI to the interrupt-driven SPI slave, where they are
stored in a buffer. The characters are then read from the
buffer and sent back to the PC, where they are displayed in
a terminal window.
In a real implementation, there would be two separate boards
and you would likely use hardware SPI in the Master board.
I had to use a software Master for this demo because it's
all done in one PIC, and the PIC only has one hardware SSP
module.
// This program demonstrates an SPI slave with the PicDem2-Plus
// board. Both Master and Slave are contained in one 16F877
// chip. The Slave uses the hardware SPI pins on Port C and
// Port A.  The Master uses software SPI on Port B.
// See the following website for an explanation of SPI modes.
// http://www.totalphase.com/support/articles/article03/
#include <16F877.H>
#device *=16
// Software SPI pins used by Master.
#define MASTER_SS  PIN_B2  // Connect to Slave \SS (Pin A5)
#define MASTER_SCK PIN_B3  // Connect to Slave SCK (Pin C3)
#define MASTER_SDI PIN_B4  // Connect to Slave SDO (Pin C5)
#define MASTER_SDO PIN_B5  // Connect to Slave SDI (Pin C4)
// Use Charlie U's SPI mode definitions.
#define SPI_MODE_0_0 0x4000
#define SPI_MODE_0_1 0x0000
#define SPI_MODE_1_0 0x0010
#define SPI_MODE_1_1 0x4010
// Variables used for the SPI slave receive buffer.
#define BUFFER_SIZE  80
int8 buffer[BUFFER_SIZE];
int8 next_in = 0;
int8 next_out = 0;
#define spi_kbhit (next_in != next_out)
// Create an interrupt-driven SPI receive
// buffer, similar to the way it's done for
// RS-232 in the CCS example file, EX_SISR.C.
#int_ssp
void ssp_isr(void)
buffer[next_in] = spi_read();
next_in++;
if(next_in >= BUFFER_SIZE)
   next_in = 0;
// Wait for a character to become available
// in the spi slave's receive buffer.  Then
// get it from the buffer and return it.
int8 spi_bgetc(void)
int8 c;
while(!spi_kbhit);
c = buffer[next_out];
next_out++;
if(next_out >= BUFFER_SIZE)
   next_out = 0;
return(c);
// Transmit a byte via the software SPI port.
// Use SPI mode 0,0.
void master_spi_write(char data)
int8 i;
disable_interrupts(GLOBAL);
output_low(MASTER_SS);
for(i = 0; i < 8; i++)
    if(bit_test(data, 7))
       output_high(MASTER_SDO);
       output_low(MASTER_SDO);
    delay_us(5);
    output_high(MASTER_SCK);
    delay_us(5);
    output_low(MASTER_SCK);
    data <<= 1;
output_high(MASTER_SS);
char c;
// Initialize the hardware SSP for SPI Slave mode.
setup_spi(SPI_SLAVE | SPI_MODE_0_0);
// Initialize the software Master SPI pins.
output_float(MASTER_SDI);
// Enable interrupts for the SPI slave.
clear_interrupt(INT_SSP);
enable_interrupts(INT_SSP);
// If the user presses a key on the PC, get the
// character and send it out the software SPI
// master port.   Then when the character is
// received by the hardware SPI slave and placed
// in its buffer, get it and send it back to the PC.
   if(kbhit())  // Char available from PC ?
      c = getc();  // If so, get it
      master_spi_write(c);  // Send it via SPI
   if(spi_kbhit)  // Char available from SPI slave ?
      c = spi_bgetc();  // If so, get it
      putc(c);  // Send it to the PC
temopic
PostPosted: Sat Sep 06, 2008 11:50 am     Reply with quote
Could you help us with a similar example for Master and one for Slave? different files
I am using the pic18f2520 and CCS 4.065
My idea is to have one Master which will send to Slave everything it gets from rs232 via SPI and a Slave which will send everything it receives from rs232 to Master via SPI.
I am having problems to make this a seamless communications bridge.
I am using 1 master and 8 slaves all 18f2520.
Have somebody use a similar protocol? this is not for a commercial use.
