bebeto
| CCP1 in 18F1320 question |
Posted: Mon Aug 18, 2008 9:21 pm |
Hi guys, i try to use this code, but CCP1 value is inconstant.
Whats happening? I use in wrong way?
I use this code to measure frequency and start when one pulse is 2x old.
| Code: | #int_ccp1
void handle_ccp1_int()
if (flag==1)
t1=ccp_1;
setup_ccp1(CCP_CAPTURE_rE);
flag=0;
pulso++;
}else{
setup_ccp1(CCP_CAPTURE_fE);
if (sync==0)
if ( t1>tt+tt )
sync=1;
pulso=1;
set_timer1(0);
flag=1;
pulso++;
tt=t1;
if (sync==1) Mapa();
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
setup_ccp1(CCP_CAPTURE_RE);
clear_interrupt(INT_CCP1);
enable_interrupts(int_ccp1); |
Posted: Tue Aug 26, 2008 9:33 am |
| CCP module work inconstant. I trie to measuring a square pulse and CCP value in printf is inconstant. |
Posted: Tue Aug 26, 2008 10:12 am |
The CCP works.
Plenty of people have used it with no problems.
Likeliest thing to cause trouble, is the signal levels. The CCP, uses a _Schmitt_ input, which requires the input to go up to 0.8* the supply voltage, and down to 0.2* the supply. The latter is not a problem, but the former is higher, than is guaranteed by things like a 'normal' TTL output. If your signal is not reliably doing this, then you will get erratic behaviour.
bebeto
Posted: Tue Aug 26, 2008 1:26 pm |
the input signal level.
I make some measuring to check signal level and dont find problem.
If i run program in proteus all work fine, but if i write in pic and run the measuring results is diferent.
timer 0 didn't work wwith have ccp (timer1) process? |
Ttemah Guest
Posted: Tue Aug 26, 2008 2:52 pm |
How to not show useful data....
You don't show what the zero volt level is. If B is the zero level (which is what the graph looks like), then it looks as if this signal is swinging to something like +2v, and -2.5v. This will never work. You would need to connect it's ground to a voltage of about 2.5v...
I'd suspect this is where your problem lies.
bebeto
Posted: Wed Aug 27, 2008 11:23 am |
Ttemah
Channel 1 as 16f628 output to 18f1320 input.
Channel 2 is a 3ms 18f1320 output.
Time hight in channel 1 is 200us. |
Posted: Wed Aug 27, 2008 2:50 pm |
The channel two display, shows the channel reference level near the _bottom_ of the waveform. The channel one display, shows the reference level in the _middle_ of the waveform. Then channel 2, is shown as having a unit amplitude of 50v, not 5v. Suggests you have the scope set for *10 probes, and the probe set to *1, otherwise how can the logic output from the chip give such an amplitude?...
Set both probes to *10, make sure the scope is set to use *10 probes, set the vertical scale to 5v, and set the cursor level to 0v, then we can see what the waveforms actually represent.
So far, the information is still useless.
