Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
MCP23016 simple driver
PICoHolic
PostPosted: Thu Nov 30, 2006 3:54 am     Reply with quote
#ifndef  MCP23016
#define  MCP23016
#define MCP_write 0B01000000
#define MCP_read  0B01000001
#define GP0     0x00
#define GP1     0x01
#define OLAT0   0x02
#define OLAT1   0x03
#define IPOL0   0x04    // INPUT POLARITY PORT REGISTER 0
#define IPOL1   0x05    // INPUT POLARITY PORT REGISTER 1
#define IODIR0  0x06    // I/O DIRECTION REGISTER 0
#define IODIR1  0x07    // I/O DIRECTION REGISTER 1
#define INTCAP0 0x08 // INTERRUPT CAPTURE REGISTER 0
#define INTCAP1 0x09 // INTERRUPT CAPTURE REGISTER 1
#define IOCON0  0x0A // I/O EXPANDER CONTROL REGISTER 0
#define IOCON1  0x0B // I/O EXPANDER CONTROL REGISTER 1
void InitMCP23016(int8 AddressSelect, int8 P0, int8 P1)
   i2c_start();
      delay_us(20);
   i2c_write(MCP_write | (AddressSelect << 1));
      delay_us(20);
   i2c_write(IODIR0);
      delay_us(20);
   i2c_write(P0);
      delay_us(20);
   i2c_write(P1);
      delay_us(20);
   i2c_stop();
      delay_us(20);
   i2c_start();
      delay_us(20);
      delay_us(20);
   i2c_write(IOCON0);
      delay_us(20);
   i2c_write(0x01);
      delay_us(20);
   i2c_stop();
      delay_us(50);
void GetGPx(int8 AddressSelect, int8 *P0, int8 *P1)
   i2c_start();
      delay_us(20);
      delay_us(20);
   i2c_write(GP0);
      delay_us(20);
   i2c_stop();
      delay_us(50);
   i2c_start();
      delay_us(20);
   i2c_write(MCP_read | (AddressSelect << 1));
      delay_us(20);
   *P0 = i2c_read();
      delay_us(20);
   *P1 = i2c_read(0);
      delay_us(20);
   i2c_stop();
      delay_us(50);
void SetGPx(int8 AddressSelect, int8 P0, int8 P1)
   i2c_start();
      delay_us(20);
      delay_us(20);
   i2c_write(OLAT0);
      delay_us(20);
   i2c_write(P0);
      delay_us(20);
   i2c_write(P1);
      delay_us(20);
   i2c_stop();
      delay_us(50);
void GetINTGPx(int8 AddressSelect, int8 *P0, int8 *P1)
   i2c_start();
      delay_us(20);
      delay_us(20);
   i2c_write(INTCAP0);
      delay_us(20);
   i2c_stop();
      delay_us(50);
   i2c_start();
      delay_us(20);
      delay_us(20);
   *P0 = i2c_read();
      delay_us(20);
   *P1 = i2c_read(0);
      delay_us(20);
   i2c_stop();
      delay_us(50);
void SetGPREG(int8 AddressSelect, int8 REG, int8 Data)
   i2c_start();
      delay_us(20);
      delay_us(20);
   i2c_write(REG);
      delay_us(20);
   i2c_write(Data);
      delay_us(20);
   i2c_stop();
      delay_us(50);
#endif
DonWare
PostPosted: Wed Jan 24, 2007 10:43 am     Reply with quote
I borrowed some of this code for a hot job I'm working on.
Thanks very much !!!
I'm using a PIC16F877 and MCP23016. I was wondering how important the delays are in this code ?
The reason I ask is that I'm using this device to control 2 step motors and the delays slow down my maximum possible speed.
In retrospect it was probably a bad idea using the 23016 for this - but I'm stuck right now. Does anybody have any thoughts on this ?
Thanks in advance, Don
PICoHolic
PostPosted: Wed Jan 24, 2007 10:51 am     Reply with quote
At most you can reduce the delay_us(20) to delay_us(12)
and the 50 us to probably 25!
(Go back to the datasheet)
I dont know. Try to go down with the delay bit by bit Laughing
Good Luck
Keep me posted!
BoydNielsen
PostPosted: Fri Aug 15, 2008 6:15 am     Reply with quote
I have never used the MCP23016 I/O Expander and have a presssing project where this will help greatly. Your "MCP23016 simple driver" appears to be well written. However, I have a question: Going through the code, it looks like the driver only addresses Port 0 (GP0, OLAT0, IPOL0, IODIR0, INTCAP0, and IOCON0). Do I need to duplicate the functions for Port 1? Or, am I missing something?
Thanks,
Boyd
PICoHolic
PostPosted: Mon Aug 18, 2008 1:10 am     Reply with quote
No you dont have to duplicate anything...
It works perfect for both ports.
Regards
