jds-pic
| suggest a PIC development board with the following features: |
Posted: Wed Aug 13, 2008 2:13 pm |
please suggest a PIC development board with (or approximately with) the following features:
- PIC with native USB, e.g. PIC 18F4550, @20MHz.
- USB port powered/DC power optional/selectable.
- 9Vdc -> 12Vdc power input.
- RS232 port.
- LEDs, 3 or 4 would be good.
- LCD, 2 x 16 or so. backlight nice, not req'd.
- pushbutton switches.
- small breakout area or expansion connector -- some way to use the board for bigger things; e.g. for adding memory (SEEPROM), or for attaching the board to sharks with lasers on their heads.
- cost < US$100, prefer < US$75
- commonly available from a vendor that will be around for some time, e.g. if i buy 10 units now, i can buy 6 more units in 6 months.
CCS, sparkfun, etc don't seem to have anything that meets most of these. btw, a modular approach is ok; e.g. an LCD that sits on an expansion header.
suggestions welcomed.
thanks much,
jim / jds-pic
newguy
Posted: Wed Aug 13, 2008 2:31 pm |
| Have a look at Mikroelectronika. http://www.mikroe.com/en/tools/ After a quick look it seems as though they may have several boards with the features you want, but not at the price you want. I've never purchased products from them, but I did have a few former students who did. They were happy with the development boards they purchased. |
drh
Joined: 12 Jul 2004 Posts: 194 Location: Hemet, California USA
Posted: Wed Aug 13, 2008 2:50 pm |
Another site to check
www.olimex.com _________________ David |
Posted: Wed Aug 13, 2008 4:55 pm |
Yes, Olimex was the company I was thinking of too.
This board for EUR24,95 seems to meet the specifications, except you have to add your own LCD.
A separate LCD has the advantage that it's easier to mount in a housing and you can choose the LCD to fit your application's requirements.
Also promising: http://www.olimex.com/dev/pic-lcd3310.html.
For EUR49,95 you get: 48x48 pixel display, USB, joystick, SD/MMC connector AND a 3-axis accelerometer! A perfect fit for your shark/laser project. :-)
Note: the prices are excluding VAT. EU-members will be charged an extra 20% VAT. |
jds-pic
Posted: Wed Aug 13, 2008 10:12 pm |
| ckielstra wrote: | Yes, Olimex was the company I was thinking of too.
For EUR49,95 you get: 48x48 pixel display, USB, joystick, SD/MMC connector AND a 3-axis accelerometer! A perfect fit for your shark/laser project. :-). |
i had looked at the Olimex boards prior, but there would be a lot of foundation work for the students to do -- namely, wire up the LCD and the RS232 level converter before any actual SW experimentation could start. i don't think my "requirements" are that esoteric yet i can't find an LCD-equipped dev board which has native USB and a serial port.
thanks for the leads.
jim / jds-pic |
newguy
Posted: Wed Aug 13, 2008 10:25 pm |
http://melabs.com/ ME Labs have a USB development board, but it's $180.
Since this is for students, is there any chance you can lay out a board yourself and distribute the thing as a kit? It would be quite inexpensive, particularly if you order 100 boards at a time. The same goes for 100 of each part for the kit.
ME Labs actually posts the schematic for each of their boards, ie here for their USB board: http://melabs.com/downloads/LABXUSCH_06.PDF. It wouldn't be hard to quickly bang up your own solution. If it was a kit the students could add to it as they saw fit as well, for instance opting for a backlit LCD instead of the non-backlit "base" model. |
jds-pic
Posted: Thu Aug 14, 2008 7:35 am |
| newguy wrote: |
Since this is for students, is there any chance you can lay out a board yourself and distribute the thing as a kit? |
it's an "introduction to programming the PIC" type course, not an "introduction to hand placement of SMT parts" type course...
nevertheless it is an option we are considering for the long term.
jim / jds-pic |
mmprestine
Joined: 13 Jan 2004 Posts: 29 Location: Green Bay, Wisconsin
jds-pic
Posted: Thu Aug 14, 2008 8:04 am |
matt,
nice find -- that is the exact setup i am currently looking at.
jim / jds-pic |
