SPI MSB/LSB
boulder
SPI MSB/LSB
PostPosted: Fri Aug 08, 2008 5:57 pm     Reply with quote
I have a question about SPI. I use setup_spi() to configure SPI, and I realizes that it does not have an option for MSB/LSB, transfer from b7/b0. So, I guess there is a default selection for it. Do you know which one is default? MSB or LSB?
Thanks.
newguy
PostPosted: Fri Aug 08, 2008 6:19 pm     Reply with quote
I'm pretty sure that MSB first is the default. At least that's what works with my projects/code. Smile
PostPosted: Fri Aug 08, 2008 7:46 pm     Reply with quote
True, the SPI hardware transmits MSB first and this is the standard for most other SPI devices I know of.
In the V4 compiler you can configure a software SPI driver (#use SPI) which is configurable to sent MSB or LSB first
boulder
PostPosted: Mon Aug 11, 2008 9:33 am     Reply with quote
Thanks.
