help interrupts on change...
help
PostPosted: Fri Aug 08, 2008 2:17 am     Reply with quote
hi, my interrupts on change cant work, temp is always is zero...
input for
#define X_IN input(pin_b5)
#define Y_IN input(pin_b6)
is PWM, how to get it work?
#include <16F917.h>
#device adc=8
#FUSES NOWDT                      //Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOPUT                    //No Power Up Timer
#FUSES PROTECT                  //Code protected from reads
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOCPD                    //No EE protection
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NODEBUG                  //No Debug mode for ICD
#use fast_io (B)
#define LCD_ON
#define OUT_LED PIN_B3
  #ZERO_RAM
INT1 start=0;
int8 cnt=0;
int16 temp=0,X_VAR=0,Y_VAR=0;
#int_RB
RB_isr()
   temp=get_timer1(); clear_interrupt(int_RB);
#include "LCD1.c"
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_lcd(LCD_DISABLED);
   setup_timer_0(RTCC_INTERNAL);//setup_wdt(WDT_DIV_512);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   setup_vref(FALSE);
 set_tris_b (0b11110111);
   enable_interrupts(GLOBAL);enable_interrupts(INT_RB);
   setup_oscillator(OSC_4MHZ);
set_tris_a (0xff);
output_high(OUT_LED);
output_low(OUT_LED);
      lcd_init();
            lcd_gotoxy(1,1);
            printf(lcd_putc,"A sensor              ");
   restart_wdt();
cnt++;
            lcd_gotoxy(1,1);
            Printf(lcd_putc,"GX=%lu  T=%lu       ",X_VAR,temp);
            lcd_gotoxy(1,2);
            printf(lcd_putc,"GY=%lu  C=%u       ",Y_VAR,cnt);
}//while
}//main
