Issue with math
JerryR
Issue with math
PostPosted: Mon Jul 28, 2008 6:20 pm     Reply with quote
I've been looking at the results I get from simple math for an hour and cannot find the reason why I get the results I do. I've broken down the code to its basic elements. The contents of the EEPROM is shown as comments in the code.
Please take a look and tell me where I'm going wrong.
Compiler version 3.249 and code for a PIC18F4520 controller.
Thanks for any help
//this routine converts SN ASCII strings stored in EE to int32 format for display
SN_TO_INT32()
int32 A,B,C,D,E,F,G,H,J;                                 //get this unit's serial number from EE
//EEPROM @ Unit_SN_EEAdr =    0x33     EEPROM Contents
//EEPROM @ Unit_SN_EEAdr+1 =  0x32
//EEPROM @ Unit_SN_EEAdr+2 =  0x33
//EEPROM @ Unit_SN_EEAdr+3 =  0x33
//EEPROM @ Unit_SN_EEAdr+4 =  0x33
//EEPROM @ Unit_SN_EEAdr+5 =  0x33
A = (read_eeprom (Unit_SN_EEAdr)-0x30);               //= 3       OK
B= ((read_eeprom (Unit_SN_EEAdr+1)-0x30) * 10);       //= 20      OK
C= ((read_eeprom (Unit_SN_EEAdr+2)-0x30) * 100);      //= 44    WHAT !
D= ((read_eeprom (Unit_SN_EEAdr+3)-0x30) * 1000);     //= 3000    OK
E= ((read_eeprom (Unit_SN_EEAdr+4)-0x30) * 10000);    //= 30000   OK
F= ((read_eeprom (Unit_SN_EEAdr+5)-0x30) * 100000);   //= 0
G= read_eeprom (Unit_SN_EEAdr+2);                     //=0x33     OK
H= read_eeprom (Unit_SN_EEAdr+2)-0x30;                //=0x03     OK
J= ((read_eeprom (Unit_SN_EEAdr+2)-0x30) * 100);      //= 44      *What!
PostPosted: Mon Jul 28, 2008 6:44 pm     Reply with quote
The read_eeprom() function returns a byte, and 100 is contained within
a byte. The compiler thinks you are doing 8-bit math and it doesn't
automatically promote it to 16-bit math. The solution is to tell the
compiler to use 16-bit math by casting one of the operands to 16-bit.
You can do this most easily by appending an 'L' to the 100.
JerryR
Math
PostPosted: Tue Jul 29, 2008 5:57 am     Reply with quote
Hi PCM:
I hope I can call you by your first name Laughing I appreciate your reply. I wonder why the correct answer appears in variables D anf F? If it hadn't I certainly would have tried casting.
Thanks again!
SherpaDoug
PostPosted: Tue Jul 29, 2008 6:50 am     Reply with quote
Because 1000 and 10000 are 16 bit constants, so the compiler uses 16 bit math. 100 is a valid 8 bit value so 8 bit math is used.
JerryR
Math
PostPosted: Tue Jul 29, 2008 7:38 am     Reply with quote
SherpaDoug:
OK, now that makes sense! No casting required on the equations with int32 varables.
I guess I need to cast EVERYTHING when using mixed length variable / constant.
Good lesson, thanks.
