armondo522 Guest
| Ember development kit |
Posted: Mon May 19, 2008 12:05 pm |
| Is anyone having problems downloading demo programs into sensor boards. |
bart.dinger
Posted: Tue Jul 01, 2008 6:48 pm |
Yes. The CCS ICD doesn't seem to like the PIC16F886 and reports it as unknown device ID 2062.
It works fine using the Microchip ICD2, but still a bit of pain having to swap tools. I've emailed CCS support, hopefully they have an easy fix.
Its kinda funny they ship a dev kit that doesn't like the software thats included  |
crystal_lattice
Posted: Wed Jul 02, 2008 3:49 am |
| Just a question concerning the 16F886, does the ccs icd not work with the dev board pic combo or does the icd not work with the pic at all? I'm currently busy with a project and planning to use the pic16f886/7 but now i'm oncerned that the ccs icd is not going to work at all. please advise |
bwhiten
| 16F887 |
Posted: Wed Jul 02, 2008 7:43 am |
| I am definitely using the CCS ICD with the 16F887 for almost 6 months now. I am programming the component but not doing any debugging at present. |
bart.dinger
Posted: Thu Jul 03, 2008 6:23 pm |
ARRGGGHHHHH This is getting really frustating. The CCS support doesn't seem to be much help at all. It doesn't help I'm on the otherside of the world and have to wait 24 hours between emails :(
My emails have all included screen shots, but its like their support guy isn't even looking at them.
The CCS ICD just refuses to detect the PIC16F886 (Unkown device ID 2062) When I do the 'hardware diagnostics' thing from the ICD.exe program it says this device is not supported and to contact CCS support for an update.
I'll just go back to using MPLAB/ICD2. |
bwhiten
Posted: Thu Jul 03, 2008 9:10 pm |
| What revision of the compiler are you using and how old is your ICD? |
bart.dinger
Posted: Fri Jul 04, 2008 1:51 pm |
Compiler is current (i think its 4.075), and the ICD-U is one that came with the ember dev kit about a month ago. I tried updating the firmware.
What I don't get is if I run the hardware diagnostic thing, and check device compatibility, and manually enter the device, the resulting data doesn't have have any ticks next the 'ICD Programming', only debug. So to me that says the software isn't compatible with programming the PIC16F886. I think its a bug with the current version of the ICD software or the devices library.
I was begining to think it was 'me', so I gave the whole kit to a colleague and after an hour he phones me and says he can't get the ICD to program the ember sensor board...
Maybe I'll just remove the 886 and stick on an 887, which incidentally seems to work fine with ICD-U. I don't think its the ember sensor board itself, but at least changing the PIC will rule that out. |
nbahr Guest
Posted: Fri Aug 08, 2008 10:26 am |
It sounds like a bad DEVID mask to me. If you go into Tools->Device Editor and select the 16F886, under the identification tab there are two important values. Next to HW Device ID, it should say 2060. Next to HW Mask, it should read 3FE0.
If these values are correct, and you are still experiencing problems, I would recommend installing the latest version of the ICD program off the CCS website. Version 2.26 of the firmware was released recently. |
