Steve H. Guest
| POTS Data Modem |
Posted: Fri May 30, 2008 10:09 pm |
Believe it or not the Telephone interface is alive and well.
Does anyone have a suggestion for a embedded POTS Modem - preferable a small module that can be embedded on a project board? A radio receiver driven by a PIC 16F877 FYI.
I know about Cermetek as a supplier.
Any others come to mind?
The applications unit volume is only several hundred per year so I'm not sure that building my own would ever have a payback.
Thanks in advance for the help!
Steve H. |
| POTS modem |
Posted: Sat May 31, 2008 5:53 am |
It's best to use a premade modem that is already 'certified' by the DOC or FCC,'homemade stuff' will need type approval for your product($$$)
Perhaps the easiest solution ,if space permits, is to buy regular PC external modems and gut them and use into your product.
For several years I used'old' 8 bit modemcards as well as 'super I/O' cards(2 RS232,floppy,hard disk,LPT) to easily interface with PICs.They are/were cheap,reliable,and very easy to cut code for.
Just another option....
Jay |
Steve H Guest
Posted: Sat May 31, 2008 9:21 am |
| Thanks Jay - That's a good idea. |
treitmey
Steve H. Guest
Posted: Sat May 31, 2008 7:13 pm |
Thanks Ttreitmey, that's a good suggestion too.
Steve H |
Steve H Guest
| Solution - POTS data Modem |
Posted: Fri Jun 20, 2008 10:39 pm |
OK - I have a good solution - the RJ Modem series from MultiTech. Easy to use - in just an hour or so I have a working Modem Solution. This little modem works great! Very simple to use.
HTH - Steve H. |
